    LoPy4 alarm callback not repeating periodically
    2 Posts 2 Posters 40 Views 2 Watching
      joshhulnz
      I have a LoPy4 which I am trying to measure an ADC voltage on periodically. I have an alarm that I am trying to trigger interrupts every five seconds with. Here is what the code I am testing with looks like:
      from machine import ADC
      from machine import Timer
      import utime
      adc = ADC(0)
      #ADC channels for baterry voltage monitoring
      adc_b1 = adc.channel(pin = 'P20', attn=ADC.ATTN_11DB)
      list = []
      #Measures battery voltage
      def battery_voltage():
          for i in range(0, 35):
              read = adc_b1.voltage()
              list.insert(i, read)
          avg_reading_b1 = sum(list)/len(list)
          list.clear()
          bat_1 = str(round(avg_reading_b1/1000, 2)) #String and round
          print(bat_1)
      battery_alarm = Timer.Alarm(battery_voltage(), s=5, periodic=True)
      def main():
          while(1):
              continue
      main()
      The functions battery_voltage() gets called once after the file has been successfully uploaded. After that, the program continues to loop but battery_voltage() does not get called again. Is there something wrong with how I am setting up the alarm?
        robert-hh @joshhulnz
        @joshhulnz
        a) write: Timer.Alarm(battery_voltage, s=5, periodic=True) without the brackets.
        Optimization:
        b) in the main loop, I would use a short sleep instead of the continue statement
        c) I you just need the average, you do not have to collect the values. Just add them up while reading, e.g.
            avg = 0
                avg += adc_b1.voltage()
            print(round(avg/35000, 2))
