NB-IOT dropping after an hour or so
  • Hi,
    I have a FiPy connected to a pyscan. It can connect to pybytes and send data happily for an hour or so. After this time, it drops. The more attempts to get it working consecutively, the more frequently the drops occur, to the point where I'm lucky if I have more than 5 minutes of connectivity. Typically the drops are due to illegalinstruction errors or loadprohibited errors. Looking around the forum, this appears to be related to power. Can anyone elaborate on the issue? My code below.
    Many thanks in advance (and yes my experience with microcontrollers is minimal!)
    Tim
    Code here-
    ################### imports
    #print("Starting imports")
    from pyscan import Pyscan
    from MFRC630 import MFRC630
    from machine import SD, I2C, RTC, Pin
    from PCA9554 import PCA9554 #for io expander
    import _thread
    import os
    import DS3231 #for RTC
    import gc
    #for network check
    from network import LTE
    lte=LTE()
    netstate = False
    #from network import WLAN
    #wlan = WLAN()
    #imports for pybytes
    from _pybytes_config import PybytesConfig
    from _pybytes import Pybytes
    pybytes_config = PybytesConfig().read_config()
    pybytes = Pybytes(pybytes_config)
    #setup for watchdog
    #from machine import WDT
    #wdt = WDT(timeout=50000)  # enable it with a timeout of 50 seconds
    #wdt.feed()
    #print("imports successful")
    ################# Functions start
    def chiplog(tap): #local recording of taps as csv on sd card
        f = open("/sd/taplog.csv", "a")
        f.write(tap)
        f.write("\n")
        f.close()
    def time_calc(): #get time from external RTC
        time_now = ds.DateTime()
        year = str(time_now[0])
        month = str(time_now[1])
        day = str(time_now[2])
        weekday =str(time_now[3])
        hour = str(time_now[4])
        minute = str(time_now[5])
        second = str(time_now[6])
        if len(second) == 1:
            second = "0" + second
        if len(month) == 1:
            month = "0" + month
        if len(day) == 1:
            day = "0" + day
        if len(hour) == 1:
            hour = "0" + hour
        if len(minute) == 1:
            minute = "0" + minute
        #millisecond = str(time_now[7])
        time_stamp = year + "-" + month + "-" + day + " " + hour + ":" + minute + ":" + second
        del year
        del month
        del day
        del hour
        del minute
        del second
        del time_now
        return(time_stamp)
    def minute_check(): #get last digit
        del time_now
        if len(minute) > 1:
            minute = minute[1:2]
        return(minute)
    def chipscan(): #picking up the NFC chips
        # Send REQA for ISO14443A card type
        atqa = nfc.mfrc630_iso14443a_WUPA_REQA(nfc.MFRC630_ISO14443_CMD_REQA)
        if (atqa != 0):
            # A card has been detected, read UID
            uid = bytearray(10)
            uid_len = nfc.mfrc630_iso14443a_select(uid)
            #print("Detected")
            if (uid_len > 0): # A valid UID has been detected, print details
                #print("UID Detected")
                uid_str=map(str,uid)
                uid_str=''.join(uid_str)
                #print(uid_str)
                return(uid_str)
                return("misread")
            return("no_chip")
        #reset for next time
        nfc.mfrc630_cmd_reset()
        time.sleep(0.1)
        # Re-Initialise the MFRC630 with settings as these got wiped during reset
        nfc.mfrc630_cmd_init()
    def posindication(): #beep and flash for successful scan
        global count
        #buzzer.set()
        buzzer(True)
        led.set()
        time.sleep(0.3)
        #buzzer.reset()
        buzzer(False)
        led.reset()
        count = 0
    def negindication(): #periodic flash
        global count
        if count == 30:
            led.set()
            time.sleep(0.2)
            led.reset()
            count = 0
            count = count + 1
    def setexternalrtc():
        buzzer(True)
        led.set()
        time.sleep(0.5)
        buzzer(False)
        time.sleep(0.5)
        buzzer(True)
        time.sleep(0.5)
        buzzer(False)
        #start ntp sync
        rtc.ntp_sync("0.uk.pool.ntp.org",update_period=3600)
        time.sleep(5)
        if rtc.synced() == True:
            print("Time synced")
            time_now = rtc.now()
            #set date
            ds.Year(time_now[0])
            ds.Month(time_now[1])
            ds.Day(time_now[2])
            #set time
            ds.Hour(time_now[3])
            ds.Minute(time_now[4])
            ds.Second(time_now[5])
            #indicate
            buzzer(True)
            time.sleep(0.5)
            buzzer(False)
            print("Time not synced")
        led.reset()
    def network_check():
        global netstate
        if lte.isconnected() == True:
            netstate = True
        #elif wlan.isconnected() == True:
        #    netstate = True
            netstate = False
        return(netstate)
    ################# SubFunctions end and main thread functions start
    def mainloop(): #main loop looking for and handling UIDs from chips
        global taps_pending
            uid_send = chipscan()
            if uid_send == "misread":
                negindication()
            elif uid_send == "no_chip":
                negindication()
            elif uid_send == "115771133000000":
                setexternalrtc()
                #lock.acquire()
                tap = ("uid"+uid_send+"timestamp"+time_calc())
                taps_pending.append(tap)
                chiplog(tap)
                print(tap)
                del tap
                posindication()
                #lock.release()
            #wdt.feed()
            time.sleep(0.05)
    def checkpending(): #checks the unsent list and sends and unsent taps
        global taps_pending
        pybytes.start()
        time.sleep(5)
        pybytes.send_signal(3,"power on")
            if network_check() == True:
                if len(taps_pending) > 0:
                    print("Sending " + taps_pending[0])
                    pybytes.send_signal(1,taps_pending[0])
                    del taps_pending[0]
                elif minute_check() == "0"or minute_check() == "5":
                    pybytes.send_ping_message()
                    print("Ping Sent")
                    time.sleep(70)
                    #gc.collect()
                    print("Sleeping with connection")
                    #pybytes.send_signal(2,"sleeping with  connection")
                    gc.collect()
            elif network_check() == False:
                print("Disconnecting - no connection")
                pybytes.disconnect()
                time.sleep(60)
                print("Attempting to reconnect")
                pybytes.connect()
                time.sleep(10)
                pybytes.send_signal(2,"reconnected")
                print("Sleeping without connection")
                gc.collect()
    ################# main thread functions end
    #setup SD card
    sd = SD()
    os.mount(sd, "/sd")
    #setup buzzer using Pin
    buzzer = Pin('P10', mode=Pin.OUT)
    #tests buzzer using pin
    buzzer(True)
    buzzer(False)
    #setup LEDs using IO expander
    led = PCA9554(line=1, direction=0)
    #tests LED using IO expander
    led.set()
    led.reset()
    #wdt.feed() #feed timeout
    #clock setup
    rtc = RTC() #internal RTC module
    i2c = I2C(0, pins=('P22','P21')) #setup i2c interface
    ds = DS3231.DS3231(i2c) #establish connection to i2c clock
    #setup taps pending list and counter
    taps_pending = []
    count = 0
    #setup scan
    py = Pyscan()
    nfc = MFRC630(py)
    nfc.mfrc630_cmd_init() # Initialise the MFRC630 with some settings
    #setup thread lock
    lock = _thread.allocate_lock()
    #thread start
    _thread.start_new_thread(mainloop,())
    _thread.start_new_thread(checkpending,())
  • Hi,
    There can be many reasons for a coredump (I think is what you are describing?). I tried to make a guide to help you debug the output yourself here: https://docs.pycom.io/advance/coredump/, but it is quite complicated and requires some experience. If you keep getting the same traceback in your coredump, I can check the cause for you if you can tell me the exact firmware you are using (incl Pybytes/ Pygate version). At this time Im unable to check your code as it requires some external components I dont have..
    You mention they are typically caused by this, so not always? We know it is possible for the LTE connection to drop, as the environment is constantly changing. We therefor advise to only connect to LTE when you need to send data, and then disconnect again.
    Best,
