<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PyGate with Gpy India Frequencies]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I just bought the PyGate (868 MHz version) with Gpy and I'm going through the <a href="https://development.pycom.io/tutorials/all/pygate/" target="_blank" rel="noopener noreferrer nofollow ugc">PyGate Setup Instructions</a>.</p>
<p dir="auto">I am based out of India and was wondering which configuration to use to set up a gateway using this setup. If anyone can share a snippet it would be great as I don't want to brick the devices.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.pycom.io/topic/6395/pygate-with-gpy-india-frequencies</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 05:31:23 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/6395.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Sep 2020 18:34:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PyGate with Gpy India Frequencies on Wed, 30 Sep 2020 11:30:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sarya" aria-label="Profile: sarya">@<bdi>sarya</bdi></a> said in <a href="/post/34746">PyGate with Gpy India Frequencies</a>:</p>
<blockquote>
<p dir="auto">m based out of India and was wondering which configuration to use to set up a gateway using this setup. If anyone can share a snippet it would be great as I don't want to brick the devices.<br />
Thanks</p>
</blockquote>
I will have this information available in the documentation very soon. In the meantime, you can use this:</p>
<ol>
<li>You can find the config file for your region <a href="https://github.com/TheThingsNetwork/gateway-conf" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></li>
<li>Make a file called <code>config.json</code> in your project and paste the appropriate region settings to that file</li>
<li>Add the following to the bottom of the <code>config.json</code> file:<pre><code class="language-json">...
	"gateway_ID": "XXXXXXXXXXXXXXXX",
	"keepalive_interval": 10,
	"stat_interval": 30,
	"push_timeout_ms": 100,
	"forward_crc_valid": true,
	"forward_crc_error": false,
	"forward_crc_disabled": false
</code></pre>
</li>
<li>Edit the <code>gateway_ID</code> to reflect yours.</li>
</ol>
]]></description><link>https://forum.pycom.io/post/34758</link><guid isPermaLink="true">https://forum.pycom.io/post/34758</guid><dc:creator><![CDATA[Gijs]]></dc:creator><pubDate>Wed, 30 Sep 2020 11:30:02 GMT</pubDate></item></channel></rss>
