PyGate with Gpy India Frequencies
  • Hi,
    I just bought the PyGate (868 MHz version) with Gpy and I'm going through the PyGate Setup Instructions.
    I am based out of India and was wondering which configuration to use to set up a gateway using this setup. If anyone can share a snippet it would be great as I don't want to brick the devices.
  • @sarya said in PyGate with Gpy India Frequencies:
    I will have this information available in the documentation very soon. In the meantime, you can use this:
    1. You can find the config file for your region here
    2. Make a file called config.json in your project and paste the appropriate region settings to that file
    3. Add the following to the bottom of the config.json file:
      	"gateway_ID": "XXXXXXXXXXXXXXXX",
      	"keepalive_interval": 10,
      	"stat_interval": 30,
      	"push_timeout_ms": 100,
      	"forward_crc_valid": true,
      	"forward_crc_error": false,
      	"forward_crc_disabled": false
    4. Edit the gateway_ID to reflect yours.
