    Sporadic [Errno 113] EHOSTUNREACH from HTTP server
    4 Posts 2 Posters 1.7k Views 3 Watching
      crankshaft
      I have a simple http server, just one connection from the local area network, nothing fancy.
      I am unable to keep the server running permanently, normally within an hour it will die with : [Errno 113] EHOSTUNREACH
      Having googled this, it appears that most people say it is DNS lookup related, however there is no DNS lookup involved and it is the client connecting to the server on an ip address and not the server trying to contact another hostname.
      Any suggestions on how I can trap / prevent this error as I I am all out of ideas !
      This is not all of the codse with the imports etc, but it's the most important part:
      def close():
        global conn
        conn.sendall('\n')
        conn.close()
        try:
          global conn
          sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
          sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
          # sock.settimeout(5)
          sock.bind(('', 80))
          sock.listen(1)
            conn, addr = sock.accept()
            raw = conn.recv(1024).decode('UTF-8')
            if not raw:
              print('Null Request.')
              close()
              print(addr,'OK')
              conn.sendall('<h1>Hello</h1>\n')
              close()
            gc.collect()
        except Exception as e:
          print(e)
        crankshaft
        I suspect this maybe either related to the wlan power saving or the conversion of usocket library,
        The "EHOSTUNREACH" error appears to be an exception that is thrown when the socket is configured as a client and attempts to connect to another host, however in this application the socket is configured as a server NOT a client ?!
          crankshaft
          Ahh, just spotted this:
            File "", line 1, in e�li�p��t��x��|��}e�}i�}h�}c�|��}a�}��}��|��}a�}��}b�|f�}d�}��}b�|i�}d�}��}e�}i
            File "dev.py", line 58, in <module>
            File "dev.py", line 56, in z
            File "www/server.py", line 144, in run
          OSError: [Errno 113] EHOSTUNREACH
          dev.py and server.py are my files, but what is file""
          is
            livius @crankshaft
            @crankshaft
            i am in the same position as you
            but only in current firmware
            other wipy with 1.5.0 work ok many days..
            but with 1.5.1 above error
