    No repl after upgrade to FW1.5.1.b1 with new FW updater tool (SOLVED)
    2 Posts 2 Posters 788 Views 2 Watching
      pmb_nl
      I had a problem that the board wasn't accessible anymore via repl or visible via IP address after upgrade of the firmware. The LED was RED without blinking.
      I solved the issue by redoing the same firmware upgrade but now without the high speed.
      This worked. Perhaps interesting for others with the same issue.
      Best regards,
      Peter
      • R Offline
        rskoniec
        Thank you for sharing. Btw, I've always uncheck High speed transfer option, because simply it never worked for me. ;)
