    Mystery with network.WLAN on a FiPy
    network.wlanfipyrequested opera
    3 Posts 2 Posters 78 Views 2 Watching
      paul_tanner
      Line 5 throwing the error "OSError: the requested operation is not possible"
      sounds like a problem with connect()
      (I am, of course, using valid ssid and password)
      import network
      wlan = network.WLAN(mode=network.WLAN.STA)
      wlan.connect('your-ssid', auth=(network.WLAN.WPA2, 'your-key'))
      while not wlan.isconnected():
          time.sleep_ms(50)
      print(wlan.ifconfig())
      Any ideas?
        paul_tanner @paul_tanner
        OK solved by using a different set of APIs from the micropython site.
        import network
        from network import WLAN
        wlan = WLAN(mode=WLAN.STA)
        nets = wlan.scan()
        for net in nets:
            if net.ssid == '13GC':
                print('Network found!')
                wlan.connect(net.ssid, auth=(net.sec, 'tobytoby'), timeout=5000)
                break
        print (wlan.ifconfig())
        I conclude that there's a fair amount or documentation that can't be trusted, presumably because of "upgrades"
          jcaron @paul_tanner
          @paul_tanner What's the value of net.sec in you case?
