ulab.fft.spectrogram performance drops for 8192 points and beyond
Re: Pycom firmwares with single/double precision and ulab module
I am using the custom firmware
LoPy4_pybytes_ulab_sp_thread_v1.20.2.rc10-g87b47d16e_2020-08-06provided by user @rcolistete (thanks!).I have a question regarding the speed of the ulab.fft.spectrogram function.
import ulab as np import utime x=np.arange(2048) t1=utime.ticks_ms(); y=np.fft.spectrogram(x); t2=utime.ticks_ms(); print(utime.ticks_diff(t2,t1)) 12 x=np.arange(4096) t1=utime.ticks_ms(); y=np.fft.spectrogram(x); t2=utime.ticks_ms(); print(utime.ticks_diff(t2,t1)) 25 x=np.arange(8192) t1=utime.ticks_ms(); y=np.fft.spectrogram(x); t2=utime.ticks_ms(); print(utime.ticks_diff(t2,t1)) 866 x=np.arange(16384) t1=utime.ticks_ms(); y=np.fft.spectrogram(x); t2=utime.ticks_ms(); print(utime.ticks_diff(t2,t1)) 1995 x=np.arange(32768) t1=utime.ticks_ms(); y=np.fft.spectrogram(x); t2=utime.ticks_ms(); print(utime.ticks_diff(t2,t1)) 3466One can see that there is a large increase in computation time between 4096 and 8192 points long arrays.
I would have expected a delay of around 50 ms for a 8192 points array.Is there any explanation for this?
Anything I could do to get faster computation times for 8192 or even 16384 points long arrays?Thanks in advance for your support!
Nicolas
@nteolane
Where do you find this "LoPy4_pybytes_ulab_sp_thread_v1.20.2.rc10-g87b47d16e_2020-08-06" ?
I would like to use ulab library but I don't find how ?
@nteolane My explanation would be RAM cache misses. If the RAM usage exceeds a certain limit, then the RAM cache start to miss and the RAM pages have to be swapped in and out from the cache to the SPI RAM (RAM connected by a SPI bus) each swap takes a few 100 µs.
