    I2C on Pytrack2 pyport
    6 Posts 3 Posters 103 Views 4 Watching
      lolloz
      Hi all,
      I connected a I2C sensor to the pyport on pytrack2. Than my script is:
      "from machine import I2C, Pin
      i2c = I2C(0, pins=(SDA,SCL))
      i2c.init(I2C.MASTER, baudrate=115000)
      i2c.scan()"
      Anyone can help me about how can I refer to SDA and SCL on pyport? I don't find in any place which Pins I have to indicate.
      thank you for any help.
        The pin numbers are P22 for SDA, and P21 for SCL
        They are indicated (maybe in an obscure way) here: https://docs.pycom.io/datasheets/expansionboards/pysense2/ in the pinout
        L 2 Replies Last reply Reply Quote 0
          lolloz @Gijs
          @Gijs Hi thank you so much for your answer. I try to access I2C using P22 and P21 but I got "bus error". Do you have success using I2C on sensor port with these Pins?
            lolloz @Gijs
            @Gijs P21 and P22 seems for gps and accelerometer
              jcaron @lolloz
              @lolloz I2C is a shared bus with one master and potentially many slaves. If you use other devices on that bus, you need to re-use the same I2C device.
              L 1 Reply Last reply Reply Quote 1
                lolloz @jcaron
                @jcaron thank you for your replay. my question is: have you ever tried to access a sensor connected to pyport on pytrack2 and you success on this? My fear is that thare is some issue on this port.
