    ILI9163C display on WiPy 3.0 + EB v3.1
    9 Posts 3 Posters 83 Views 3 Watching
    • N Offline
      NickBoots
      Hello, trying to get a ILI9163C to work on my WiPy 3.0 via an Expansion Board v3.1, but having no luck yet.
      It's one of those Red PCB displays with '1.44' SPI 128 x 128 v1.1' written on the back.
      I connected it as followed:
      SPI Screen <-> WiPy 3.0
      LED/D/C    <-> Pin 5
      SCK        <-> Pin 10
      SDA        <-> Pin 9
      A0/Data    <-> Pin 11
      Reset      <-> Pin 6
      CS         <-> Pin 7
      Gnd        <-> Gnd
      VCC        <-> 3.3v
      Then proceeded to try it with the following library: https://github.com/PrestonHackspace/esp32-micropython/blob/master/sys/lib/ili9163.py
      And using this script to test it:
      from ili9163 import ILI9163_SPI
      from machine import Pin, SPI
      spi = SPI(0, mode=SPI.MASTER, baudrate=100000, polarity=0, phase=0)
      ili = ILI9163_SPI(128, 128, spi, Pin('P5'), Pin('P6'), Pin('P7'))
      ili.text('Hello World', 0, 0, 1)
      The display seems to stay off until the ili object is constructed, after which the backlighting turns on, I assume that's just because Pin 5 starts powering it, but after that, nothing seems to make it show anything, so I'm a bit at a loss here, anyone any idea what might work?
      • N Offline
        NickBoots
        No one any idea? Still stuck here.
          robert-hh @NickBoots
          @NickBoots You have to call
          ili.show()
          to make visible what you have set up in framebuf with ili.text()
          • N Offline
            NickBoots
            Tried it out, but it sadly did not show anything still.
              @NickBoots It looks like the Pin assignment for SPI is wrong. Since you use the default pins, you have to use P10 for CLK and P11 for MOSI, which is the data pin. The terms SDA and SCL are used for I2C interfaces.
              • N Offline
                NickBoots
                Hmm, weird, the pinout on the board names these, at least, as it literally reads out on the bottom, the pins are labelled as follows:
                LED
                SCK
                SDA
                A0
                RESET
                CS
                GND
                VCC
                Yet the text above it claims its an SPI display...
                  @NickBoots Yes, you must check which mode the device is in. There should a data sheet. A0 is definitely not required for SPI, It looks like the I2C address select.
                  But still the default pin assignments for I2C and SPI are different. I2C uses P9 and P10, SPI uses P10, P11 and P14.
                    Jean Bikie @NickBoots
                    @NickBoots can you look this link : https://lemariva.com/blog/2016/12/wipy-2-0-weather-report-box
                    may be it could help you.
                      Jean Bikie
                      did you find a solution ?
