    Core panics during sqnsupgrade as well as generally
    2 Posts 1 Posters 47 Views
    • M Offline
      michael87
      I've been plagued with core panics with this GPy module that I started using, only purchased in the last 2 weeks approx.
      At first the device was running an old version main firmware which had some different function in micropython (I migrated base code from a program which was working on LoPy4), so updated the main firmware to 1.20.2r1. Then when I implemented LTE the core panics became increasingly obvious.
      Checking the forums it appeared that maybe the issue was then the LTE modem stability (modem had 43xxx) so I tried a sqnsupdate procedure.
      Even with a cleanly erased GPy, it proceeds to core panic every time during sqnsupdate, not neccessarily in the same update position and not necessarily the same type high level core panic (I don't know what all the dump means) but usually IllegalInstructionError. The most notable was a DoubleExceptionError, it would not even give me the register or dump afterwards.
      Also to test, I loaded a program without LTE being started and after a length of time it does still core panic. At the moment I am running the P9 LED blinker tutorial but it has not been able to elicit the fault within the same kind of timeframe (usually less than 10 minutes, the sqnsupdate is probably much quicker than that).
      Have tried:
      Reformat and reload SD card sqns dup and elf
      Disable pybytes at boot, not use pybytes on firmware updater (I did not have it activated anyway)
      Load 1.20.2rc7
      Erase/format all on firmware updater
      Different USB cable
      format /flash explicitly
      checked that RTS and CTS jumpers are not fitted
      I am at a bit of a loss as to what to do to resolve this.
      The GPy is on an expansion board 3.1, previously working with the Lopy4. I have tested it without my application expansion hardware.
      This is 1.20.2rc7 during sqnsupdate
      >>> import os
      >>> os.fsformat('/flash')
      >>> import machine
      >>> machine.reset()
      ets Jun  8 2016 00:22:57
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2140
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19760
      entry 0x400a05bc
      Pycom MicroPython 1.20.2.rc7 [v1.11-6d01270] on 2020-05-04; GPy with ESP32
      >>> from machine import SD
      >>> sd = SD()
      >>> os.mount(sd,'/sd)
        File "<stdin>", line 1
      SyntaxError: invalid syntax
      >>> os.mount(sd,'/sd')
      >>> import sqnsupgrade
      >>> sqnsupgrade.run('/sd/CATM1-41065.dup','/sd/updater.elf')
      <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
      >>> GPy with firmware version 1.20.2.rc7
      Attempting AT auto-negotiation...
      Session opened: version 1, max transfer 2048 bytes
      Sending 430284 bytes: [########################################] 100%
      Waiting for updater to load...
      Attempting AT wakeup...
      Session opened: version 1, max transfer 8192 bytes
      Sending 6160982 bytes: [############################            ]  71%Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
      Memory dump at 0x400e07a0: b4432500 1d202aa0 000000f0
      Core 1 register dump:
      PC      : 0x400e07a7  PS      : 0x00060730  A0      : 0x400fea98  A1      : 0x3ffd7740
      A2      : 0x00004062  A3      : 0x00000002  A4      : 0x00000000  A5      : 0x00000002
      A6      : 0x00000000  A7      : 0x000001ae  A8      : 0x800e07a4  A9      : 0x3ffd7720
      A10     : 0x00004062  A11     : 0x3ffc4400  A12     : 0x00000000  A13     : 0x3f9e1ef8
      A14     : 0x000000fe  A15     : 0x000001f6  SAR     : 0x0000001a  EXCCAUSE: 0x00000000
      EXCVADDR: 0x00000000  LBEG    : 0x40092298  LEND    : 0x400922a3  LCOUNT  : 0x00000000
      Backtrace: 0x400e07a7:0x3ffd7740 0x400fea95:0x3ffd7770 0x40108cd7:0x3ffd7790 0x40101500:0x3ffd7830 0x400fd811:0x3ffd7860 0x400fd8a1:0x3ffd7880 0x40109853:0x3ffd78a0 0x40101500:0x3ffd7940 0x400fd811:0x3ffd79b0 0x400ffdf5:0x3ffd79d0 0x400fd811:0x3ffd7a20 0x401097c5:0x3ffd7a40 0x40101500:0x3ffd7ae0 0x400fd811:0x3ffd7b10 0x400fd8a1:0x3ffd7b30 0x40109853:0x3ffd7b50 0x40101500:0x3ffd7bf0 0x400fd811:0x3ffd7c20 0x400fd8a1:0x3ffd7c40 0x40109853:0x3ffd7c60 0x40101500:0x3ffd7d00 0x400fd811:0x3ffd7d30 0x400fd8a1:0x3ffd7d50 0x40109853:0x3ffd7d70 0x40101500:0x3ffd7e10 0x400fd811:0x3ffd7e40 0x400fd8a1:0x3ffd7e60 0x40109853:0x3ffd7e80 0x40101500:0x3ffd7f20 0x400fd811:0x3ffd7f90 0x400fd83e:0x3ffd7fb0 0x400e12e5:0x3ffd7fd0 0x400e1570:0x3ffd8070 0x400e000d:0x3ffd80b0
      bDgAAAEAAAAPAAAAbAEAAA==
      /EP8P4B2/T/kgf0/
      wHX9P4CB/T8lagQAGEH8PxhB/D/8Q/w/EEH8Pw4AAABUYvs/VGL7P/xD/D8AAAAA
      CwAAAOhR/T9NaWNyb1B5AAAAAAAAAAAAAQAAAOSB/T8AAAAAIAcGAAsAAAABAAAA
      0E37PxyS/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      Z4RAPwAAAABoGAlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
      eGkQgKcHDkAwBwYAmOoPQEB3/T9iQAAAAgAAAAAAAAACAAAAAAAAAK4BAACkBw6A
      IHf9P2JAAAAARPw/AAAAAPgenj/+AAAA9gEAABoAAAAAAAAAAAAAAJgiCUCjIglA
      AAAAAAAAAAD4Hp4/BDIIQDy99z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAEHf9PwAAAADajBCAcHf9P2sAAACuAQAA
      AQAAAHB3/T8BAAAAAAAAAAAAAAD4Hp4/AAAAAAAAAAADFRCAkHf9P2vAQj9pwEI/
      9B6ePwEAAAAaAAAAAQAAABTYD4AweP0/sOuUP7DrlD+geP0/YHj9PwMVEICQd/0/
      CAAAAEwfnj9IH54/QB+ePwIAAAAWAAAAFNgPgCB4/T8BAAAAsOuUPxTYD4AweP0/
      sOuUP7DrlD+iihCACQAAAAcAAABAH54/AAAAABEAAAAAAAAA4B6eP0wfnj9IH54/
      WHn9PxyS/D8JAAAAIAsGAPQenj8w////AAAAANDErj+k2A+AYHj9P3AAlT8DAAAA
      AAAAAAAAAAA4Gp4/ijIIQOAenj9Yef0/ZAAAADB4/T9WmBCAgHj9PwIAAAAAAAAA
      AAAAAFh5/T8DAAAA0iEAAAMVEICgeP0/DAAAAJ28Qj9Uef0/MHn9P8h4/T8wef0/
      FNgPgEB5/T+w65Q/sOuUP0B6/T/geP0/AxUQgKB4/T8IAAAAcHn9P2x5/T9kef0/
      AAAAAAcAAAAIef0/cHn9PxTYD4CAef0/FNgPgEB5/T+w65Q/sOuUP6KKEIDgeP0/
      CAAAAGR5/T8AAAAABAAAAAAAAABAef0/cHn9P2x5/T/Qef0/wHn9PxTYD4CAef0/
      VHn9PzD///+evEI/AQAAAPj9D4Cwef0/8BOePwMAAADwE54/nLxCP1B5/T9kef0/
      sOuUP3AAlT8QFJ4/cAeeP60EvAAQFJ4/0BOeP0ASnj+k2A+AAHr9P1AAlT8BAAAA
      AAAAAAAAAACUef0/rHn9P0B5/T/Qef0/AAAAAIB5/T8U2A+A0Hn9PzAZnj8IAAAA
      AAAAANB5/T8QFJ4/AAAAAMiXEIAgev0/MBmePwEAAABAEp4/0BOePxAUnj8BAAAA
      gHn9P2gTnj8AAAAA0Hn9P1aYEIAgev0/AAAAAAAAAAAAAAAAaBOePwEAAAADAAAA
      AxUQgEB6/T8EAAAAA7xCPwAAAABoE54/aHr9P9B6/T8U2A+A4Hr9P7DrlD+g9JQ/
      UHv9P7h6/T8DFRCAQHr9PwgAAACwE54/rBOeP6QTnj//////EwAAAHj4+z8AAAAA
      aRQQgMB6/T8U2A+A4Hr9P7DrlD+g9JQ/oooQgLR6/T8DAAAAsBOePwMAAAALAAAA
      AAAAAFATnj+wE54/rBOePxwblT/gev0/bGkQQAEAAABkE54/MP///wS8Qj8AAAAA
      pNgPgBB7/T/QAZU/BAAAAAMAAAAAAAAAmOlDPwEAAABQE54/HBuVP2QAAADgev0/
      VpgQgDB7/T8EAAAAAwAAAAMAAAAcG5U/FgAAAFYiAAADFRCAUHv9PywAAAAhoUI/
      FBuVPwEAAAAAAAAAAQAAABTYD4Dwe/0/oPSUP6D0lD9gfP0/AAAAAAMVEIBQe/0/
      CAAAAOAblT/cG5U/1BuVPxoAAAAzAAAAAAAAAAAAAAABAAAA0Hv9PxTYD4Dwe/0/
      oPSUP6D0lD+iihCA0JP8PwYAAADgG5U/CgAAABwAAAAAAAAAABuVP+AblT/cG5U/
      aBqVPwEAAAAAAAAAAQAAABQblT8w////IqFCPwIAAACk2A+AIHz9PyAIlT8BAAAA
      CgAAAAAAAACY6UM/AQAAAAAblT9oGpU//AAAAPB7/T9WmBCAQHz9PwAAAAAKAAAA
      CgAAAGgalT8AAAAAAAAAAAMVEIBgfP0/VAAAAB2BQj9kGpU/AQAAAIh8/T/wfP0/
      FNgPgAB9/T+g9JQ/oPSUP3B9/T8AAAAAAxUQgGB8/T8IAAAA9BqVP/AalT/oGpU/
      DwAAACQAAAAAAAAAcHz9PxTYD4AAff0/FNgPgAB9/T+g9JQ/oPSUP6KKEIAEAAAA
      AwAAAOgalT8LAAAAFwAAAAAAAABQGpU/9BqVP/AalT9IDpU/5NVAP8AElT8A75Q/
      ZBqVPzD///8egUI/AgAAAKTYD4Awff0/oAeVPwEAAAALAAAAAAAAAOAOlT+KMghA
      UBqVP0gOlT+QAAAAAH39P1aYEIBQff0/AAAAAAsAAAALAAAASA6VPwkAAABaIgAA
      AxUQgHB9/T9cAAAAs3dCP0QOlT8BAAAAAAAAAAEAAAAU2A+AEH79P6D0lD9wkvw/
      gH79PwAAAAADFRCAcH39PwgAAADcDpU/2A6VP9AOlT8HAAAAJgAAAAAAAAAaAAAA
      AwAAAPD0lD8U2A+AEH79P6D0lD9wkvw/oooQgDBmCUACAAAA0A6VPwAAAAAeAAAA
      AAAAADAOlT/cDpU/2A6VP0B//T8ckvw/BwAAAJ+h/QBEDpU/MP///7R3Qj8CAAAA
      pNgPgEB+/T9wBJU/AgAAAAAAAAAAAAAAAAAAAIoyCEAwDpU/QH/9P5gAAAAQfv0/
      VpgQgGB+/T8CAAAAAAAAAAAAAABAf/0/JHD0PwAAAAADFRCAgH79PwwAAAAcDpU/
      OH/9PxB//T+ofv0/EH/9PxTYD4Agf/0/cJL8P3CS/D/Qf/0/AgAAAAMVEICAfv0/
      CAAAAEh//T9Ef/0/PH/9PwAAAAAFAAAA0DIAADBmCUD/////AgAAABTYD4Agf/0/
      cJL8P3CS/D+iihCA+BCVPwgAAAA8f/0/AAAAAAUAAAAAAAAAIH/9P0h//T9Ef/0/
      AAAAACB//T9wf/0/+BCVPzh//T8w////HQ6VPxAIlT9B2A+AkH/9P3ANlT8AAAAA
      cA2VPxsOlT8wf/0/PH/9P3CS/D9g/EA/cASVPwAAAAAA75Q/wASVP/////8DAAAA
      kT4IgIB//T+gf/0/AAAAAAAAAAAAAAAAcA2VPwAAAAAgf/0/AAAAAAAAAABgf/0/
      6BIOgLB//T9wDZU/AAAAAAAAAAAAAAAABQAAAAAAAABzFQ6A0H/9P3ANlT8WAAAA
      AAAAAAAAAAAAAAAAqA2VPxAADoBwgP0/8hhAPwAAAAAAAAAAAID9P3MVDoDQf/0/
      GE38PwAAAAAWAAAAXAAAACIAAAD+////DQAAAPhM/D8NAAAAwH79PxAADoBwgP0/
      8hhAPwAAAABkEg6A+BCVP5AQlT9QgP0/cID9P7YYQD8AAAAA+Ez8PzgAAABw95Q/
      FgAAAHCA/T+kZwEAAAAAABYAAABcAAAAIgAAAP7///8AAAAAsID9Pzj4+z8BAAAA
      OQAAADgAAADwDJU/CAAAAAAAAACwgP0/AAAAAByS/D8AAAAAAQAAAAAAAAA0//o/
      AAAAAICB/T8AAAAAAAAAAAEAAAClpaWlpaWlpaWlpaVoMghAOPwNQDAABQAAAAAA
      gIH9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAACQshsAAAAAAP//////////
      //////////8RV6YjAPAfALCA/T8AAAAAAAAAAAAAAAAAACgAAAAAADyB/T8AAAAA
      uEX8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAIyB/T8AAAAA
      BLP7P5Cs/T/wrf0/
      kKz9P5Ct/T8+ZgQAoED8P6BA/D8Es/s/mED8PxQAAABgs/s/AAAAAASz+z8AAAAA
      BQAAAPSd/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAPCt/T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
      aDIIQH5SCUAwDQYAJAEOgFCt/T8+ZgQARN37PwAAAAAA/wAAAAD/AAAAAP9+UgmA
      MK39PwEAAAA+ZgQABLP7PwEAAAD+AAAAIwAGAAAAAAD//z+zAAAAAK0uCUDDLglA
      +f///2g0CEABAAAAMGYJQEzp9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAASz+z8BAAAA/gAAACMABgAAAAAAcK39PwAAAAAAAAAA
      AAAAAAD/AAAAAP8AAAAA/wAAAACQrf0/AAAAAAAAAAAAAAAAAQAAAHZI/D8AAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnK39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      QLn7P6C3+z84ufs/
      oLf7P9C4+z9+a33QvL77PzxA/D9Aufs/NED8PxkAAAA/YXJtsdhzy0C5+z8AAAAA
      AAAAADy1+z9JRExFMADsFl8i/iZqh1cAAAAAADi5+z8AAAAAIQAGAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFKBCg==
      aDIIQI75IEAwCQYARpIWgGC4+z8AAAAAAAAAAAAAAACQt/s/AwAAACMABgAYkPw/
      /////5w//D88QPw/GzsJgHC3+z8DAAAAIwAGAAAAAABguPs/AAAAAAAAAAAAAAAA
      AAAAAGg0CEBwt/s/MGYJQIz09T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAA0VQmAgLj7PyAAAAABAAAA
      //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAAMQ//D8AAAAAEPf8PyhC/D8AAAAA
      AAAAANC4+z8AAAAAAAAAAETd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      tL77PxC9+z+svvs/
      EL37P0C++z9CV5wgPED8P0i5+z+0vvs/NED8PxkAAADV/+PbLMjwM7S++z8AAAAA
      AAAAALC6+z9JRExFMQD03H3d1IgepIEAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJWIYA==
      aDIIQI75IEAwCwYARpIWgNC9+z8AAAAAPED8Pxs7CYAAvfs/AwAAACMABgAjAAYA
      8PD7PyAAAAAgAAAA//8/s6urAAADAAAAIwAGAAAAAAAQvvs/AAAAAAAAAAAAAAAA
      AAAAAGg0CECrqwAAMGYJQPz59T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAABoNAhAEPf8PzBmCUA0VQmA8L37PyAAAAABAAAA
      //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAAMQ//D8gAAAAEPf8PyxC/D8AAAAA
      AAAAAEC++z8AAAAAAAAAAETd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      zK/7P9Ct+z/Er/s/
      0K37P2Cv+z9hZgQAKED8PyhA/D/Mr/s/IED8PwcAAAC4n/s/uJ/7P8yv+z+wn/s/
      EgAAAMih+z90aVQAIAAAAICkAADQsfsAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADm6PQ==
      aDIIQIRECUAwCQYAtUUYgJCu+z+Mn/s/MK/7P9if+z8AAAAA4J/7PwAAAACERAmA
      cK77PwAAAAAnAAAARN37PyhC/D/+AAAAAAAAAAAAAAAc6/U/AAAAAOE6GEDuOhhA
      AAAAAGg0CEAoQvw/MGYJQBzr9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAIjIF4Cgrvs/oJxEP6Cu+z+HyheA0K77P/////8wr/s/
      AAAAADpmBABkAAAA1MkXQCcAAACQrvs//gAAAAAAAADYyheA4K77P5SxRD9wAJQ/
      G1QXgACv+z9I/Pw/MK/7PxtUF4AAr/s/SPz8PzCv+z8nAAAA/////zpmBAAAAAAA
      AAAAADCv+z8MahdAAAAAANTJF0CUsUQ/DGoXQAAAAABEA/0/RAP9P0AD/T9AA/0/
      AAAAAGCv+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      IMv7P8DJ+z8Yy/s/
      wMn7P7DK+z8AAAAAFED8PxRA/D8gy/s/DED8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
      CgAAABzB+z9UbXIgU3ZjAFLoyJNpa8EAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKV3zw==
      aDIIQGVkCUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAA4Qvw/MEL8PwEAAABlZAmA
      YMr7PwAAAABE3fs/jD/8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAGg0CEAAAAAAMGYJQGwG9j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAGwG9j8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
      AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      lLH7P1Cc/T/snf0/
      UJz9P4Cd/T9tYWMAXL/9P8DY+z+Usfs/sD/8PxQAAABdObo9Y2FsX5Sx+z8AAAAA
      BQAAAPCN/T9TbWFydENvbmZpZwBjYWwAAQAAAOyd/T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
      aDIIQPC/AEAwAAYAmE0JgBCd/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
      q6sAAOzc+z8jAAYAlLH7PwEAAAD+AAAAIwkGAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAAGg0CEABAAAAMGYJQDzZ9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAByXwmAIJ39P0Td+z8FAAAA
      h2sOgECd/T8BAAAALEL8P5Sx+z8BAAAA/gAAACAAAAAAAAAAYJ39PwAAAAAAAAAA
      KEL8P0Td+z+cP/w/oED8PwAAAACAnf0/AAAAAAAAAABUTfw/AAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjJ39PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      VL/9P7C9/T9Mv/0/
      sL39P+C+/T/oVxapOHz7P5yx+z9Uv/0/sD/8PxQAAAAKi639xBqjk1S//T8AAAAA
      BQAAAFCv/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAEy//T8AAAAAIQAGAAUAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAANPIzA==
      aDIIQPC/AEAwAAYAmE0JgHC+/T8AAAAAIwAGACAABgBMAQAAVQAAAFCd/T///z+z
      q6sAAOzc+z8jAAYAVL/9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAAGg0CEABAAAAMGYJQJz69z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAByXwmAgL79P0Td+z8GAAAA
      Ql0OgKC+/T8BAAAALEL8P1S//T8BAAAA/gAAAOxj+z8AAAAAwL79PwAAAAAAAAAA
      KEL8P0Td+z+cP/w/oED8PwAAAADgvv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7L79PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      MHz7P7Cc+z84nvs/
      sJz7P9Cd+z+P/BJRcMX9P1y//T8wfPs/sD/8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
      GAAAADya+z9pcGMxAMuICymku+q/F9EAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+WtQ==
      aDIIQIRECUAwAQYAVBwIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACERAmA
      UJ37PwEAAAD/////RN37PyhC/D/+AAAAIAMGABwAAAAAAD4AAAAAAJgiCUCjIglA
      /////2g0CEAoQvw/MGYJQIzZ9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAIIcCICQnfs/MID9PwEAAAAAAAAAsJ37P/w+/D/0Pvw/
      AAAAACUAAAAAAAAAIAMGAP////8AAAAA/D78P+g+/D8kfPs/AAAAANh7+z8BAAAA
      AAAAANCd+z8AAAAAAAAAAOQaFkAwgP0/AAAAAAAAAAC4EgiAgH3+PwABAADoDQBA
      AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      aMX9P8Dk/T/U5v0/
      wOT9P3Dm/T+Q0rer9Fn7Pzh8+z9oxf0/sD/8Pw4AAAAkrv0/JK79P2jF/T8crv0/
      CwAAANjG/T9JUlFzAOcR+e+5LlnVV4IAAQAAANTm/T8AAAAAIQAGAAsAAAAAAAAA
      AAAAAAzm/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsBMPg==
      aDIIQIRECUAwAwYA+DsPgIDl/T/4rf0/IOb9P0Su/T8AAAAATK79PwAAAACERAmA
      YOX9PwEAAAD/////RN37PyhC/D/+AAAAAAAAAAAAAAAsIvg/AAAAAAAAAAAAAAAA
      AAAAAGg0CEAoQvw/MGYJQCwi+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAsAAAApaWlpaWlpaWIBw6AwOX9P6CQ/D8g5v0/
      AAAAACcGAAClpaWlpaWlpf/////A5f0/0JP8PyDm/T8AAAAAAQAAAJSQ/D8YAPw/
      AAAAAFDm/T+UkPw/AAAAAHDm/T8AAAAAAAAAAAAAAAAAAAAAlJD8PwAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAg5v0/
      ABwAAHCS/D9wkvw/AAAAACwi+D8AAAAAAAAAAAAAAABwkvw/CgAAAJw//D8YQfw/
      AAAAAHDm/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAB85v0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAA==
      7Fn7P0BY+z/kWfs/
      QFj7P4BZ+z8sBgAAcHr7P3DF/T/sWfs/sD/8PxMAAADUIrexRYbJr+xZ+z8AAAAA
      BgAAAOhN+z9MVEUAbCGfllQDVoPcr04AAQAAAORZ+z8AAAAAIQAGAAYAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAL4lxg==
      aDIIQPC/AEAwCQYAmE0JgABZ+z8AAAAAIwkGACAJBgABAAAABgAAAAEAAAD//z+z
      q6sAAOzc+z8jCQYA7Fn7PwEAAAD+AAAAVMRFPxMAAAAACAAA/Bn9P/QaCUAiGwlA
      /////2g0CEABAAAAMGYJQDyV9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAALhg+z8AAAAADAAAAAAIAAByXwmAEFn7P0Td+z8JAAAA
      6w0RgDBZ+z8BAAAALEL8P+xZ+z8BAAAA/gAAAAAIAAAAAAAAUFn7PwAAAAAAAAAA
      KEL8P0Td+z+cP/w/tED8PwAAAACAWfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAABin/D8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIxZ+z8AAAAA
      aHr7P+B4+z9gevs/
      4Hj7PwB6+z+uCo1PhHL7P/RZ+z9oevs/sD/8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
      GAAAAGR2+z9pcGMwAILQSTZI2S3OOgwAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFEBeQ==
      aDIIQIRECUAwCwYAVBwIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACERAmA
      gHn7PwAAAAD/////RN37PyhC/D/+AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
      AAAAAGg0CEAoQvw/MGYJQLy19T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7P/g+/D8AAAAA
      AAAAAHqYAAD+AAAAAQAAAP////8AAAAA+D78P+g+/D8Advs/AAAAAAEAAAAAAAAA
      AAAAAAB6+z8AAAAAAAAAALBiCEAAAAAAAAAAAAAAAAAtEgiAIDz+P5g//D8fZ0A/
      AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      fHL7P+Bw+z90cvs/
      4HD7PxBy+z+dvaB3wGD7P3B6+z98cvs/sD/8PwMAAAB8Pvw/fD78P3xy+z90Pvw/
      FgAAAHhm+z9lc3BfdGltZXIAQwhbCh8AAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALM0kg==
      aDIIQIRECUAwCwYA+SMNgKBx+z9QPvw/AAAAAJw+/D8AAAAAUD78PwAAAACERAmA
      gHH7PwAAAAD/////RN37PyhC/D/+AAAAIAAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAAGg0CEAoQvw/MGYJQMyt9T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4HH7P6Q+/D+sPvw/
      AAAAAP/WAwAAAAAAAAAAAP////8AAAAAAAAAAAAAAADMrfU/AAAAAAAAAAAAAAAA
      AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKw+/D8SAAAP
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      uGD7PzAY/T/8Gf0/
      MBj9P5AZ/T9Usot9uD/8P4Ry+z+4YPs/sD/8Pw0AAABwXvs/cF77P7hg+z9oXvs/
      DAAAAAAS/T9MVEVfVUFSVF9FVlQAVkYAAQAAAPwZ/T8AAAAAIQAGAAwAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJJ64w==
      aDIIQIRECUAwBwYAeA0RgPAY/T9EXvs/ZBn9P5Be+z8AAAAAmF77PwAAAACERAmA
      0Bj9PwEAAAD/////RN37PyhC/D/+AAAAIwAGAAAAAAD//z+zAAAAAPQaCUAiGwlA
      /////2g0CEAoQvw/MGYJQExV9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAETd+z8oQvw//gAAACMABgAAAAAAMBn9P8SV/D/Alfw/
      AAAAAKNlBAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACQXvs/AAAAAJhe+z8AAAAA
      AAAAAJAZ/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAADAAAAEgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnBn9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
      uNj7PzCM/T/ojf0/
      MIz9P4CN/T8As7I5nLH7P7g//D+42Ps/sD/8PwUAAACM0vs/jNL7P7jY+z+E0vs/
      FAAAAOyB/T9ldmVudFRhc2sAs0kKrSwAAAAAAOiN/T8AAAAAIQAGABQAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKmIng==
      aDIIQIRECUAwAAYAGJEWgPCM/T9g0vs/MI39P6zS+z8AAAAAtNL7PwAAAACERAmA
      0Iz9PwAAAAD/////RN37PyhC/D/+AAAAIwAGAAAAAAClpaWlpaWlpQAAAAAAAAAA
      AAAAAGg0CEAoQvw/MGYJQDzJ9z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
      AAAAAAAAAAAAAAAAAAAAAICN/T8AAAAAAAAAAAAAAAAAAAAAMI39P8j2/D8AAAAA
      AAAAACQAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAICN/T8AAAAAAAAAADzJ9z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAACMjf0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      AAAAAAAAAAA=
      Rebooting...
      rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      ho 0 tail 12 room 4
      entry 0x400a05bc
      • M Offline
        michael87
        I wanted to post a second core panic with 1.20.2r1 from running the application, where it panics once and then panics again on reset without seeming to get into the application at all. This pattern occurs somewhat often.
        But it's being flagged as spam and I can't attach the text either.
