    ADR (Adaptive data rate) not working, stuck at socket sending.
    1 Posts 1 Posters 45 Views 2 Watching
    • B Offline
      beelzmon
      I have been trying to use LoRa with adr enabled, as below:
      lora = LoRa(mode=LoRa.LORAWAN , region=LoRa.AU915, adr = True )
      for index in (list(range(0,8))+list(range(16,65))+list(range(66,72))):
        lora.remove_channel(index)
      This initializes the LoRa and removes all the incorrect channels as per the Lora Alliance Regional parameters document for AU915.
      Next the socket:
      s.setblocking(False)
      And finally the sending loop:
        s.send(bytes)
        time.sleep(60)
      Without ADR, this process works fine. With ADR however, it sends the first time and then gets stuck on line s.send(bytes). So using ADR i only get one send and then next send doesn't work and it doesn't go to sleep either.
      Any advice would be appreciated.
