ADC causing current increase during deep sleep
Currently, some basic code sending data over LoRa and then going into deep sleep is functional, and during deep sleep has about 28 u-amps current. See below, where bytes would be replaced by data to be sent.
lora = LoRa(mode=LoRa.LORAWAN , region=LoRa.AU915, adr = True ) lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) for index in (list(range(0,8))+list(range(16,65))+list(range(66,72))): lora.remove_channel(index) s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) s.setblocking(False) while True: s.send(bytes) machine.deepsleep(60000)However, addition of the following code increases this current to 51 u-amps. This code just reads the battery voltage via ADC. See below the new code:
lora = LoRa(mode=LoRa.LORAWAN , region=LoRa.AU915, adr = True ) lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) for index in (list(range(0,8))+list(range(16,65))+list(range(66,72))): lora.remove_channel(index) adc = machine.ADC() adc.init(bits=10) adc.vref_to_pin('P22') adc.vref(1100) Channel = adc.channel(pin='P13', attn = machine.ADC.ATTN_0DB) Current_Battery_Reading= Channel.voltage() Channel.deinit() adc.deinit() s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) s.setblocking(False) while True: s.send(bytes) machine.deepsleep(60000)It looks to me that i disabled the ADC after use, but the current is still higher than without it. Is there something i am missing in order to have the deepsleep current remain at 28 u-amps, and not increase to 51 u-amps with this new code.
SOLVED: The line adc.vref_to_pin('P22') was causing this. Should only be run for calibration with a multimeter for the vref value once, is the current conclusion.
