    Light sleep: crash on wakeup
    2 Posts 1 Posters 38 Views 1 Watching
      Jean-François Milants
      Hi!
      I'm working on a project using a Lopy (wifi/ble/lora) board. The board is a bit old, but I upgraded the firmware yesterday (1.20.2.r1).
      I would like to put the Lopy into light sleep (maybe deep sleep later) and wake it up every 1 minutes or when a button is pushed.
      The button is connected on P23 (G10 on the base board) and GND.
      Here is my code:
      from machine import Pin
      print("Initializing input pin...")
      p_in = Pin('P23', mode=Pin.IN, pull=Pin.PULL_UP)
      machine.pin_sleep_wakeup(['P23'], machine.WAKEUP_ALL_LOW, True)
      print("Entering main loop...")
          print("RUN")
          machine.sleep(60000)
          print("WAKE")
      It works fine when I run the file interactively using Pymakr, but it doesn't work when I upload the file to the lopy, and reset it to run it at boot : it crashes and reboots every time it wakes up (either after 60s or when I push the button):
      RUN
      Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
      Core 0 register dump:
      PC      : 0x40095eb3  PS      : 0x00060e33  A0      : 0x80088f34  A1      : 0x3ffb7130
      A2      : 0x00000000  A3      : 0x00060e20  A4      : 0x00000001  A5      : 0x0000cdcd
      A6      : 0xb33fffff  A7      : 0x3ffdc6f4  A8      : 0x0000abab  A9      : 0x3ffb7130
      A10     : 0x00000003  A11     : 0x0000cdcd  A12     : 0x00060e20  A13     : 0x00000000
      A14     : 0x3ffb2740  A15     : 0x3ffb2d91  SAR     : 0x00000000  EXCCAUSE: 0x0000001d
      EXCVADDR: 0x00000000  LBEG    : 0x40092cd4  LEND    : 0x40092d02  LCOUNT  : 0xffffffff
      Backtrace: 0x40095eb3:0x3ffb7130 0x40088f31:0x3ffb7160 0x40086d09:0x3ffb7180 0x401432c6:0x3ffb71c0 0x400d249c:0x3ffb71e0
      7DMAAAEAAAAPAAAAbAEAAA==
      fHL7P3Bw+z90cvs/
      << GARBAGE >>
      Do I need to do something special to make it work correctly?
      Thanks!
        Jean-François Milants @Jean-François Milants
        I've just changed the version to Pycom MicroPython 1.20.0.rc13 [v1.9.4-94bb382] on 2019-08-22; LoPy with ESP32 (legacy firmware) and light sleep works as expected. I'm not sure I understand the difference between different driver types, but I don't use pybyte, so it should be ok.
        Could it be a bug in the pybyte firmware?
