Lopy4 OSError: [Errno -29312] MBEDTLS_ERR_SSL_CONN_EOF in urequests.py
Hi
I am making an access to a database through a requests.request ("PUT", url, headers = headers, data = payload) with the urequests.py library, after 5 successful accesses when I want to do the sixth one, it delivers the next mistakeFile "/flash/lib/urequests.py", line 102, in request File "/flash/lib/urequests.py", line 62, in request OSError: [Errno -29312] MBEDTLS_ERR_SSL_CONN_EOFI can't fix it.
Because it can be? -
Which network are you using? the error
MBEDTLS_ERR_SSL_CONN_EOFsignifies an error in the SSL connection for end of file, or abrupt disconnection. This could also be due to a memory error in theurequestmodule. Through google I was able to find several solutions that you can try (you'll probably be able to find them yourself as well :) )Gijs
