Deepsleep pytrack 2 issues and external RTC
  • Hi guys,
    I'm working on pytrack 2 deepsleep. What I see is that when I run a deepsleep for 6 hours, pytrack wakeup almost 10 minutes later... I'm the only one that deals with this problem. I have a DS3231 connected to pytrack, I have a chance to use this one for wakeup correctly? Using the alarm interrupt on the PIC. Any advice?
    thanks.
  • Global Moderator
    Ah sorry, I forgot to mention. We made it such that when you plug in a battery, the pysense sleep feature will work as expected,. Im not sure about using a USB cable without data connections, but I believe we sense for the 5V coming from a USB connector.
  • @Gijs Thank you so much for your answer! Yes, I'm powering the device over USB, is it possible that I get a different behaviour if I power it by +5V?
    Can you share how to enable the feature you talk about?
  • Global Moderator
    Could it be related to you powering the device over USB? There is a 'feature' in the pysense that it will wake up immediately when powered over USB (which is not properly documented in the documentation yet)
