Socket won't unbind from address when socket is terminated
  • After my successive failures using bluetooth to get my wipy's to communicate, I switched to using wifi and sockets. It does work, however using basically example code from the documentation I cannot soft reset and rerun the module without getting the error (from server wipy):
    OSError: [Errno 112] EADDRINUSE
    code used:
    client:
    def socket_thread(p):
        sconn =True
        while sconn:
            # Wait for any action to happen infinitely
            l = p.poll()
            # Start processing the actions happened
            for t in l:
                # First element of the returned tuple is the socket itself
                sock = t[0]
                # Second element of the returned tuple is the events happened
                event = t[1]
                # If any error or connection drop happened close the socket
                if(event & uselect.POLLERR or event & uselect.POLLHUP):
                    sock.close()
                    sconn = False
                    continue
                # If the socket is writable then send some data
                # The socket becomes writable if the connect() was successfull
                if(event & uselect.POLLOUT):
                    # If any error occurs during sending here, do "nothing", poll() will return with error event, close the socket there
                    try:
                        sock.send("Data to send")
                        # We only want to send one message on this socket, in the future wait only for new incoming messages
                        p.modify(sock, uselect.POLLIN | uselect.POLLHUP | uselect.POLLERR)
                    except:
                        pass
                # If any new data is received then get it
                if(event & uselect.POLLIN):
                    # If any error occurs during receiving here, do "nothing", poll() will return with error event, close the socket there
                    try:
                        r = sock.recv(12)
                        # If recv() returns with 0 the other end closed the connection
                        if len(r) == 0:
                            sock.close()
                            sconn = False
                            continue
                            # Do something with the received data...
                            print("Data received: " + str(r))
                    except:
                        pass
    def makesockets():
        telem = socket.socket()
        telem.setblocking(False)
        # Create a new poll object
        p = uselect.poll()
        # Register the sockets into the poll object, wait for all kind of events
        p.register(telem, uselect.POLLIN | uselect.POLLOUT | uselect.POLLHUP | uselect.POLLERR)
        try:
            telem.connect(socket.getaddrinfo("192.168.4.1", 1235)[0][-1])
            print('socket created')
        except OSError as e:
                if e.args[0] != uerrno.EINPROGRESS:
                    raise
        _thread.start_new_thread(socket_thread, (p,))
    server:
    def client_thread(clientsocket):
        # Receive maxium of 12 bytes from the client
        r = clientsocket.recv(12)
        if len(r) == 0:
            clientsocket.close()
            return
            # Do something wth the received data...
            print("Received: {}".format(str(r)))
        # Sends back some data
        clientsocket.send('nice')
        # Close the socket and terminate the thread
    # Set up server socket
    def createsocket():
        serversocket = usocket.socket(usocket.AF_INET, usocket.SOCK_STREAM)
        serversocket.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR, 1)
        serversocket.bind(("192.168.4.1", 1235))
        serversocket.settimeout(100)
        serversocket.listen(1)
        (clientsocket, address) = serversocket.accept()
        _thread.start_new_thread(client_thread, (clientsocket,))
  • I tried adding that but it was unsuccessful- however, the repl is staying open (not giving me a >>>) on my server after receiving a message, so it isn't finishing out whatever it's stuck open doing I think. I don't see any reason why it shouldn't finish out though? Doesn't the clientsocket.close() kill the thread?
  • You can re-initialize the socket after closing it by calling telem= socket.socket() again. This should prevent the error you are getting
1 out of 3
