    Lopy4 issue receiving in a tight loop
    7 Posts 2 Posters 81 Views 2 Watching
    • M Offline
      mbyamukama
      I have the following bit of code.
      from network import LoRa
      # Please pick the region that matches where you are using the device
      lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, bandwidth=LoRa.BW_250KHZ,coding_rate=LoRa.CODING_4_5,sf=7, tx_power=14,power_mode=LoRa.ALWAYS_ON,preamble=8,
                  tx_iq=False, rx_iq=False) # >17000 bps
      s.setblocking(False)
      i = 0
          data=s.recv(512)
          if len(data)>0:
              print('count {0} value {1} length {2}'.format(i,data,len(data)))
              i = i+1
              pycom.rgbled(0xFFD058)
              time.sleep_ms(2)
              pycom.rgbled(0x000000)
              time.sleep_ms(2)
          time.sleep_ms(1)
      I receive data well, except when I comment out the 1ms delay in the while loop. In which case I receive no data at all. The transmissions are happening slowly. About every 1 second.
        Because you have an infinite loop, removing the delay will leave no time for the watchdog timer to trigger, making the device reset internally. You can perhaps use time.sleep_us(...) instead?
        • M Offline
          mbyamukama
          • M Offline
            mbyamukama @Gijs
            @Gijs Thank you for your response.
            Any document I can read more about this?
              Its all in here: https://docs.pycom.io/firmwareapi/micropython/utime/
              Note that the 'u' in front of utime can be left when importing, its the same module
              • M Offline
                mbyamukama @Gijs
                @Gijs What I meant was any documentation on the watchdog timer versus tight loops.
                  Right, we do not have specific documentation on that (yet) I believe, as in my experience its a fundamental feature of microcontrollers in general. Could you recommend a place where you would expect this information?
