    pycom-fwtool-cli does not work on macOS Big Sur
    6 Posts 3 Posters 169 Views 3 Watching
      psrebrny
      The tool does not work on the newly release macOS version. It fails with the following output:
      File "bin/updater.py", line 25, in <module>
       File "/private/var/folders/1_/8wc1y5xd0_1bzgyyb3cf0_6c0000gn/T/pip-install-Tu89Nr/pyinstaller/PyInstaller/loader/pyimod03_importers.py", line 396, in load_module
       File "site-packages/serial/tools/list_ports.py", line 29, in <module>
       File "site-packages/serial/tools/list_ports_posix.py", line 31, in <module>
       File "site-packages/serial/tools/list_ports_osx.py", line 32, in <module>
      ValueError: dlsym(RTLD_DEFAULT, kIOMasterPortDefault): symbol not found
      [55414] Failed to execute script updater
      The problem has been reported also for esptools.py where is the solution.
      https://github.com/espressif/esptool/issues/540
        Thanks for informing us, we will get to work on this!
          psrebrny
          Great! When can we expect this tool to work on the newest macOS version?
            Thierry Demol
              Thierry Demol @Gijs
              Is it safe now to upgrade from Catalina to Big Sur or is there still some problems with pymakr and/or vsc ? Thx.
                I have not run into issues this far. You will need to update the pyserial package though (if i remember correctly) using pip3 install -U --pre pyserial
