    wipy-wlan wifi disapear after update
    4 Posts 2 Posters 52 Views 2 Watching
    • M Offline
      marc agenis
      HI,
      i've juste received two wipy3.0 with their board.
      i saw their broadcast wifi with name like wipy-wlan-XXX
      i did the firmware update as suggested via windows installer, with default options.
      After that, i never saw again the wifi signal...
      is that normal? any explanation?
      same for the two boards
      thanks,
        While that is not expected behaviour, you can re-enable the wipy-wlan as discussed in the documentation: https://docs.pycom.io/gettingstarted/programming/ftp/
        M 1 Reply Last reply Reply Quote 1
        • M Offline
          marc agenis @Gijs
          @Gijs Thanks. When i do a wlan.init(mode=WLAN_STA_AP, ssid="xxx") in the console, the AP wifi appears as expected, but does not stay after reset or unplugging. Seems that it always falls back into STAtion mode only at boot, even if I run pycom.wifi_on_boot(WLAN_STA_AP) and set a ssid name. Indeed, that's weird because on the docs it says that this config should stay. Can I change this behavior, like with the pybytes_config.json? thanks
            Right, so that is the other thing, if you are using Pybytes on boot, the AP will dissappear, as Pybytes is taking over the WLAN and making its own connection. You can start pybytes later by disabling it on boot and using
            from _pybytes import Pybytes
            from _pybytes_config import PybytesConfig
            pybytes = Pybytes(conf)
            pybytes.start()
