wifi antenna default
  • https://docs.pycom.io/firmwareapi/pycom/network/wlan/ says pycom modules default to the internal antenna for wifi but when I run
    from network import WLAN
    wlan=WLAN(mode=WLAN.STA)
    print('antenna', wlan.antenna())
    I get
    antenna 2
    since 0=internal & 1=external, 2 seems a tad ambiguous. I'm wondering if I need to run
    Pin('P12', mode=Pin.OUT); wlan.antenna(WLAN.INT_ANT)
    just to be sure?
  • Global Moderator
    I will add an entry to the documentation and a micropython constant for MAN_ANT to make this more clear, thanks!
  • @Gijs understood, thnx
  • Global Moderator
    Okay I looked into it in more detail and was able to reproduce it (I accidentally set it in a previous applications, and did not power off in between)
    so, antenna = 2 refers to ANTENNA_TYPE_MANUAL if you did not use its keyword argument in wlan= WLAN() or wlan.init(...) or the function wlan.antenna(..), meaning you can select the antenna manually by setting pin P12. In most cases, this defaults to the use of the internal antenna, as P12 is not asserted by default. To be sure, you should set the antenna type, but it is not necessary
  • @Gijs tried it on 3 different devices
    (sysname='LoPy4', nodename='LoPy4', release='1.20.0.rc13', version='v1.9.4-94bb382 on 2019-08-22', machine='LoPy4 with ESP32', lorawan='1.0.2', sigfox='1.0.1')
    (sysname='LoPy4', nodename='LoPy4', release='1.18.2.r1', version='v1.8.6-849-e0fb68e on 2018-11-26', machine='LoPy4 with ESP32', lorawan='1.0.2', sigfox='1.0.1')
    (sysname='GPy', nodename='GPy', release='1.20.1.r1', version='15b6d69 on 2019-11-02', machine='GPy with ESP32')
    all give 2 as the result, no pybytes.
  • Global Moderator
    That is quite odd, as when I run the same code on my device:
    antenna 0
    Refering to the internal antenna. Which firmware version are you running and are you perhaps using pybytes on boot?
