    Pycom 1.20.2.r2 firmware OTA not updating
    9 Posts 2 Posters 130 Views 2 Watching
      dnear1
      I've usually been able to update the firmware OTA using the pybytes website. This latest release has failed on all 12 LoPy4 devices I have remotely connected to Wifi. Is it just me, or is anyone else having issues updating from 1.20.2.r1 to 1.20.2.r2?
      • X Offline
        Xykon administrators @dnear1
        @dnear1 Can you please try again? We changed the way the binary images are stored on the software server but noticed that in the firmware up until 1.20.2.r1 it was using a static path.
        I added symlinks on the software server so the upgrade image should now be found even on devices with older firmware.
        Please let me know if that fixes your issue.
        Christian Ehlers
          dnear1
          I tried several but still getting failures.
          I'll also note that since about the time I upgraded to 1.20.2.r1, the devices seem to ping pybytes far less frequently. That's maybe a good thing if it's a cellular connection, but could it be contributing to this and other code update problems I've had? My code uses time.sleep(300) between sends. Has the pybytes behavior during time.sleep changed? Do I need to have a send_ping or similar at some interval between sleep or some other method to provide a regular heartbeat to pybytes when I want it to "be online"?
          • X Offline
            @dnear1 Can you please run the following on the LoPy4?
            pycom.nvs_set('pybytes_debug', 5)
            Then please reset the module and provide the output.
            Christian Ehlers
            D 5 Replies Last reply Reply Quote 0
              dnear1 @Xykon
              @Xykon I will later tonight. They're all remotely mounted around the metro area about 100 miles away
                dnear1 @Xykon
                @Xykon
                rst:0x1 (POWERON_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:1
                load:0x3fff8020,len:8
                load:0x3fff8028,len:2140
                ho 0 tail 12 room 4
                load:0x4009fa00,len:19760
                entry 0x400a05bc
                 ssl_params={'ca_certs': '/flash/cert/pycom-ca.pem'}
                LIS2HH12 not imported
                WMAC: 240AC4C73304
                Firmware: 1.20.2.r1
                Pybytes: 1.6.0
                Attempting to connect with network wifi
                Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
                WLAN connected? False
                Wifi connection attempt: 1
                (ssid='Ericsson2.4G-2-1', bssid=b'\x00\rgv\xb6\xc9', sec=0, channel=1, rssi=-51)
                (ssid='AREDN-20-v3', bssid=b'$\xa4<t\xfd#', sec=0, channel=1, rssi=-52)
                (ssid='DesertIslandSupplyCo', bssid=b"X\x90C'\x9a&", sec=3, channel=11, rssi=-56)
                (ssid='ATT6SH58Na', bssid=b'\xec\xa9@\xbb\xe8p', sec=3, channel=6, rssi=-59)
                (ssid='Red_Mountain_Makers', bssid=b'\xf0\x9f\xc2=!b', sec=3, channel=6, rssi=-63)
                (ssid='ATTqsHdTxi_Ext', bssid=b'\xc4A\x1e^\xe0E', sec=3, channel=11, rssi=-64)
                (ssid='ATTqsHdTxi_Ext_Ext', bssid=b'\xc4A\x1e^\xe0G', sec=3, channel=11, rssi=-69)
                (ssid='Red_Mountain_Makers', bssid=b'\xa0\x8ex2\x9f\xae', sec=3, channel=6, rssi=-70)
                (ssid='DesertIslandSupplyCo', bssid=b'hrQ\x84Y\x9e', sec=3, channel=11, rssi=-71)
                (ssid='ATTqsHdTxi', bssid=b'\xf8-\xc0dUp', sec=3, channel=11, rssi=-74)
                (ssid='DIRECT-3D-HP OfficeJet Pro 7740', bssid=b'B\xb04vj=', sec=3, channel=6, rssi=-77)
                (ssid='woodrow hall', bssid=b'\xc0\xc1\xc0\xc6@\x84', sec=4, channel=11, rssi=-79)
                (ssid='woodrow hall-guest', bssid=b'\xc0\xc1\xc0\xc6@\x86', sec=0, channel=11, rssi=-80)
                (ssid='HVP_b82ca091985a', bssid=b'\xb8,\xa0\x91\x98b', sec=5, channel=6, rssi=-83)
                (ssid='The Hangout Bham-2G', bssid=b'\xd8\xa7V\x9a\x07\xd6', sec=3, channel=11, rssi=-86)
                (ssid='OpenEVSE_1678039', bssid=b'^\xcf\x7f\x19\x9a\xd7', sec=3, channel=6, rssi=-87)
                (ssid='tla00317', bssid=b'\x88j\xe3\xa0\x03\x17', sec=3, channel=11, rssi=-92)
                WiFi connection established
                MQTT Protocol
                Packet sent. (Length: 118)
                This is PybytesProtocol.start_MQTT
                Packet sent. (Length: 44)
                Connected to MQTT mqtt.pybytes.pycom.io
                Pybytes connected successfully (using the built-in pybytes library)
                This is pack_info_message()
                __pack_message: b'010404a00581000000'
                MQTT Protocol
                Packet sent. (Length: 50)
                Scanning for known wifi nets
                Connected to Red_Mountain_Makers with IP address:0.0.0.0
                Watchdog timeout has been increased to 2147483647 ms
                self.__connection_status=1 | self.__network_type=0
                MQTT over WIFI||LTE... disconnecting MQTT
                Socket send error [Errno 118] EHOSTUNREACH
                Connected over WIFI... disconnecting
                (ssid='DesertIslandSupplyCo', bssid=b"X\x90C'\x9a&", sec=3, channel=11, rssi=-46)
                (ssid='AREDN-20-v3', bssid=b'$\xa4<t\xfd#', sec=0, channel=1, rssi=-51)
                (ssid='Ericsson2.4G-2-1', bssid=b'\x00\rgv\xb6\xc9', sec=0, channel=1, rssi=-53)
                (ssid='ATTqsHdTxi_Ext', bssid=b'\xc4A\x1e^\xe0E', sec=3, channel=11, rssi=-59)
                (ssid='ATTqsHdTxi_Ext_Ext', bssid=b'\xc4A\x1e^\xe0G', sec=3, channel=11, rssi=-63)
                (ssid='Red_Mountain_Makers', bssid=b'\xf0\x9f\xc2=!b', sec=3, channel=6, rssi=-64)
                (ssid='Red_Mountain_Makers', bssid=b'\xa0\x8ex2\x9f\xae', sec=3, channel=6, rssi=-65)
                (ssid='DesertIslandSupplyCo', bssid=b'hrQ\x84Y\x9e', sec=3, channel=11, rssi=-69)
                (ssid='DIRECT-3D-HP OfficeJet Pro 7740', bssid=b'B\xb04vj=', sec=3, channel=6, rssi=-78)
                (ssid='OpenEVSE_1678039', bssid=b'^\xcf\x7f\x19\x9a\xd7', sec=3, channel=6, rssi=-85)
                (ssid='Red_Mountain_Makers', bssid=b'\x00\x1d~\x97\xf8\x96', sec=3, channel=11, rssi=-89)
                (ssid='ATT-WI-6871', bssid=b'\xb0\xc1\x9e\x14mH', sec=3, channel=6, rssi=-90)
                MQTT Protocol
                MQTT Protocol
                This is pack_pybytes_message_variable(5, 2, bytearray(b'\x00\x00\x00\x00\x00'))
                __pack_message: b'0e05020000000000'
                MQTT Protocol
                turning fan off
                Removed default channels
                Packet sent. (Length: 49)
                US channels set
                This is pack_pybytes_message_variable(5, 2, bytearray(b'\x00\x00\x00\x04\x00'))
                __pack_message: b'0e05020000000400'
                MQTT Protocol
                Joining LoRa via OTAA
                Not yet joined...
                Not yet joined...
                Not yet joined...
                MQTT Protocol
                Starting
                This is pack_pybytes_message_variable(5, 2, bytearray(b'\x00\x00\x00\x01\x00'))
                __pack_message: b'0e05020000000100'
                MQTT Protocol
                Looping
                turning fan on
                turning fan off
                Battery Voltage =  2.745413
                Sending data!
                This is pack_pybytes_message_variable(5, 0, bytearray(b'\x00\x00\x00\x00\x00'))
                __pack_message: b'0e05000000000000'
                MQTT Protocol
                This is pack_pybytes_message_variable(5, 1, bytearray(b'\x00\x00\x00\x00\x00'))
                __pack_message: b'0e05010000000000'
                MQTT Protocol
                  dnear1 @Xykon
                  @Xykon
                  Flashing this device while in debug mode, it finally took it
                  Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; LoPy4 with ESP32
                  Pybytes Version: 1.6.0
                  >>> This is PybytesProtocol.__keep_connection(alarm=<Alarm>)
                  MQTT Protocol
                  Packet sent. (Length: 42)
                  This is PybytesProtocol.__process_recv_message()
                  This is PybytesLibrary.unpack_message(message=b'\x07')
                  MQTT Protocol
                  This is PybytesLibrary.unpack_message(message=b'\x85')
                  Performing OTA
                  Requesting: manifest.json?current_ver=1.20.2.r1&sysname=LoPy4&wmac=240ac4c73304&ota_slot=0x10000 to software.pycom.io:443 with SSL? True
                  Wrapping socket
                  Sending request
                  Result: b'HTTP/1.1 200 OK\r\nServer: nginx\r\nDate: Wed, 25 Nov '
                  Requesting: downloads/appimg/firmware_LoPy4_1.20.2.r2-pybytes.bin to software.pycom.io:443 with SSL? True
                  Wrapping socket
                  Sending request
                  Sending OTA result back 2
                  __pack_message: b'0502'
                  MQTT Protocol
                  Packet sent. (Length: 47)
                  ets Jun  8 2016 00:22:57
                    dnear1 @Xykon
                    @Xykon I was able to flash all my devices up now.. Whatever was changed between this morning and now, it works. Also, devices are reporting 'online' now, where earlier, everything was offline even though it was updating pybytes..
                      dnear1 @Xykon
                      @Xykon I had several other units I tried to fix and get online that still wouldn't flash OTA.
                      When I ran your debug commands, it did go thru.
                      >>> import pycom
                      ho 0 tail 12 room 4
                      entry 0x400a05bc
                      ho 0 tail 12 room 4
                      entry 0x400a05bc
                      ho 0 tail 12 room 4
                      entry 0x400a05bc
                      WMAC: 807D3A937CD8
                      Firmware: 1.20.2.r1
                      Pybytes: 1.6.0
                      (ssid='AREDN-20-v3', bssid=b'$\xa4<t\xfd#', sec=0, channel=1, rssi=-36)
                      (ssid='DesertIslandSupplyCo', bssid=b"X\x90C'\x9a&", sec=3, channel=11, rssi=-41)
                      (ssid='Ericsson2.4G-2-1', bssid=b'\x00\rgv\xb6\xc9', sec=0, channel=1, rssi=-48)
                      (ssid='AREDN-20-v3', bssid=b'hrQn.\xe0', sec=0, channel=1, rssi=-51)
                      (ssid='ATTqsHdTxi_Ext', bssid=b'\xc4A\x1e^\xe0E', sec=3, channel=11, rssi=-52)
                      (ssid='Red_Mountain_Makers', bssid=b'\xf0\x9f\xc2=!b', sec=3, channel=6, rssi=-56)
                      (ssid='ATTqsHdTxi', bssid=b'\xf8-\xc0dUp', sec=3, channel=11, rssi=-56)
                      (ssid='Red_Mountain_Makers', bssid=b'\xa0\x8ex2\x9f\xae', sec=3, channel=6, rssi=-63)
                      (ssid='ATTqsHdTxi_Ext_Ext', bssid=b'\xc4A\x1e^\xe0G', sec=3, channel=11, rssi=-64)
                      (ssid='DesertIslandSupplyCo', bssid=b'hrQ\x84Y\x9e', sec=3, channel=11, rssi=-67)
                      (ssid='DIRECT-3D-HP OfficeJet Pro 7740', bssid=b'B\xb04vj=', sec=3, channel=6, rssi=-74)
                      (ssid='woodrow hall-guest', bssid=b'\xc0\xc1\xc0\xc6@\x86', sec=0, channel=11, rssi=-83)
                      (ssid='OpenEVSE_1678039', bssid=b'^\xcf\x7f\x19\x9a\xd7', sec=3, channel=1, rssi=-84)
                      (ssid='Red_Mountain_Makers', bssid=b'\x00\x1d~\x97\xf8\x96', sec=3, channel=11, rssi=-86)
                      MQTT Protocol
                      MQTT Protocol
                      Performing OTA
                      Requesting: manifest.json?current_ver=1.20.2.r1&sysname=LoPy4&wmac=807d3a937cd8&ota_slot=0x210000 to software.pycom.io:443 with SSL? True
                      Wrapping socket
                      Sending request
                      Result: b'HTTP/1.1 200 OK\r\nServer: nginx\r\nDate: Fri, 27 Nov '
                      Wrapping socket
                      Sending request
                      MQTT Protocol
                      rst:0x7 (TG0WDT_SYS_RESET),boot:0x32 (SPI_FAST_FLASH_BOOT)
                      ho 0 tail 12 room 4
                      entry 0x400a05bc
                      WMAC: 807D3A937CD8
                      Firmware: 1.20.2.r2
                      Pybytes: 1.6.1
                      (ssid='DesertIslandSupplyCo', bssid=b"X\x90C'\x9a&", sec=3, channel=11, rssi=-40)
                      (ssid='AREDN-20-v3', bssid=b'hrQn.\xe0', sec=0, channel=1, rssi=-46)
                      (ssid='ATT6SH58Na', bssid=b'\xec\xa9@\xbb\xe8p', sec=3, channel=6, rssi=-53)
                      (ssid='Red_Mountain_Makers', bssid=b'\xf0\x9f\xc2=!b', sec=3, channel=6, rssi=-55)
                      (ssid='Red_Mountain_Makers', bssid=b'\xa0\x8ex2\x9f\xae', sec=3, channel=6, rssi=-60)
                      (ssid='AREDN-20-v3', bssid=b'hrQf\x9e\xf0', sec=0, channel=1, rssi=-62)
                      (ssid='HVP_b82ca091985a', bssid=b'\xb8,\xa0\x91\x98b', sec=5, channel=6, rssi=-65)
                      (ssid='DesertIslandSupplyCo', bssid=b'hrQ\x84Y\x9e', sec=3, channel=11, rssi=-66)
                      (ssid='DIRECT-3D-HP OfficeJet Pro 7740', bssid=b'B\xb04vj=', sec=3, channel=6, rssi=-72)
                      (ssid='Red_Mountain_Makers', bssid=b'\x00\x1d~\x97\xf8\x96', sec=3, channel=11, rssi=-85)
                      MQTT Protocol
                      __pack_message: b'010404a00582000000'
                      MQTT Protocol
                      Pycom MicroPython 1.20.2.r2 [v1.11-3a7776d] on 2020-11-23; LoPy4 with ESP32
                      Pybytes Version: 1.6.1
