    Not find any i2c devices with Fipy Pytrack
    4 Posts 2 Posters 74 Views 2 Watching
      Paula Mancilla
      Hi, I'm trying to connect an mpu-9250/6500 in External IO Header to SDA = P10 and SCL= P9. When I do i2c.scan() I obtain an empty list [].
      I try to do the scan because I get I2C BUS ERROR everytime I implemented a code who uses the MPU9250.
      When I Scan the pytrack port P22 and P21 return me the list [8, 16, 30] that I assume that is GPS and Accelometer from pytrack, so I don't think my I2c is bad.
      with this code I'm read
      from machine import I2C, Pin
      from mpu9250 import MPU9250
      print(os.uname())
      #SDA SCL
      i2c = I2C(0, I2C.MASTER, pins=('P10','P9'), baudrate=400000)
          devices = i2c.scan()
          print(devices)
      I tested with a multimeter the pins P10 and P9 pins from External I/O and I have 0 volt.
      Also tried with a multimeter the pins P2 and P5 and I have 3 Volts in both, when I scan those pins connected to my MPU I get an empty list.
      In addition I try to use only the FiPy alone conecting to Rx, Tx, 5V and Gnd and connect my MPU9250 to pins P22 and P21 and not found, only return [].
      Also I try with other MPU-9250 and not work.
      What's wrong? I would appreciate it very much if someone try to help.
        robert-hh @Paula Mancilla
        @Paula-Mancilla When you read 0 v it may have the reason that the pull-up resistors are missing, and you have to add them yourself. Some of the breakouts with sensors have these on the PCB, some not.
          Paula Mancilla @robert-hh
          @robert-hh Thank you for you response, I managed to scan my MPU-9250, but i2c.scan return more than ones devices. And this device changes through time.
          I only have conected MPU-9250. I try to read the values from MPU-9250 and I get an i2C BUS ERROR. Any idea?
          Greetings
            @Paula-Mancilla That indicates that the signal levels on SDA and SCL are not stable. Please check again the wiring and the pull-up resistors. Appropriate values are 10k - 1k Ohm.
