    Check sensor ready
    5 Posts 2 Posters 146 Views 2 Watching
    • E Offline
      ecabanas
      Hi all,
      I have the following code to read the sensor BME280, but If the sensor is not connect the sipy hangs...
      How could I do a previous check if the sensor is on and if not pass though the bme280 reading
      def temp_bme280():
          # this script assumes the default connection of the I2C bus
          # On pycom devuces that is P9 = SDA, P10 = scl
          i2c = machine.I2C()
          bme = bme280.BME280(i2c=i2c)
          Values= bme.values
          tempbme=res = ''.join(filter(lambda i: i.isdigit(), Values[0]))
          tempbme280=int(tempbme)/100
          return tempbme280
      Thank's guys
        robert-hh @ecabanas
        @ecabanas If the sensor is not connected you'll get an "OSError: I2C bus error" exception. The other problem may occur is the sensor is connected but never signals "ready". You may eventually change the driver to signal timeout after a suitable time. That's in the method read_raw_data().
        So you could replace the while loop for instance by:
                # Wait for conversion to complete
                for _ in range(100):  # about 1 second timeout
                    if self.i2c.readfrom_mem(self.address, BME280_REGISTER_STATUS, 1)[0] & 0x08:
                        time.sleep_ms(10)
                        break  # Sensor ready
                    raise RuntimeError("Sensor BME280 not ready")
        Edit: Updated code here: https://github.com/robert-hh/BME280
        Edit2: I just noticed that TimeoutError seems not to be know. That's strange, since it is defined in the code. So use RuntimeError instead for now.
        • E Offline
          ecabanas @robert-hh
          @robert-hh said in Check sensor ready:
          I jus
          HI @robert-hh
          Thank's for answer, Unfortunately I did not test due a huge work these days.
          What do you mean? with new library, when the sensor is not detected the read data process breaks, returns an error and the never ending loop will not be no longer?
          Thank's for your help!!
          Eduard
            robert-hh @ecabanas
            @ecabanas With the changed code an exception is raised if either:
            • the I2C connection fails or
            • the sensor does not return a value within one second wait time.
              Since an exception is raised, you have to encluse the bme280.values statement into a try/except clause and do an adequate error handling in the except path, whatever adequate is in your application.
            • E Offline
              ecabanas @robert-hh
              @robert-hh
              that's amazing!! thanks' again
