WiPy 2.0 + Expansion Board 2.0 SD Card and UART1
It is possible to use the SD Card and the UART1 serial port at the same time?
If not, Can I change the TX, RX pins for UART1?
There is any table for the alternative function of the pins (alt parameter)?Thanks and best regards,
I had the same problem. I resolve it using the next code:
from machine import SD
import osuart=UART(1,baudrate=115200,pins=('P12','P11')) ## it is important to create uart before sd
#uart.init(115200, bits=8, parity=None, stop=1,pins=('P3','P4'))
#uart.init(115200, bits=8, parity=None, stop=1,pins=('P10','P9'))
#uart.init(115200, bits=8, parity=None, stop=1,pins=('P12','P11'))while(uart.any()==0):
pass
uart.readall()sd = SD()
os.mount(sd, '/sd')check the content
os.listdir('/sd')
try some standard file operations
f = open('/sd/test.txt', 'w')
f.write('Testing SD card write operations + serial to HPoseidon')
f.close()
f = open('/sd/test.txt', 'r')
f.readall()
f.close()I hope it will be useful. Sorry for mi English.
Regards
