    New firmware release, version 1.6.0.b1
    72 Posts 13 Posters 40.6k Views 13 Watching
      livius @daniel
      @daniel said in New firmware release, version 1.6.0.b1:
      This needs to be disabled internally in the IDF. Before there was not a way to do it, but now it's possible. We'll try to do it today.
      Will be good to have possibiliti to turn it on
      e.g. if we encounter some problem with wifi it can be usefull to look at it
      and e.g. send it to you
        jmarcelino @livius
        I suspect what's being discussed is setting the CONSOLE_UART=None which is a compile time-only option so I agree with @livius until the system stabilises (especially IDF) the messages are very important for our own debugging and should stay.
        I guess you can send your own debug messages to the second UART perhaps?
        • N Offline
          Neo @livius
          @livius Looking to your posts, somehow you are a defender, or probably working/part of pycom team... but this actually doesn't matter.
          Here I am proudly part of a team of people, experts in micro&electronics, C/C++ RTOS and other related stuff, implementing dozens of IOT systems, running real product deployments.
          The onewire that we are using is from micropython git repo, module written and tested by many people. Can you point me the onewire DS1B20 that you are using?
          That module was working with 1.3.0 LopY... now is not working anymore (LoPy ). That's the point: if your work is going to be continuously impacted by regression means, frustration, waste of time and finally money.
          Have you checked your sketch with only one DS1B20 sensor running on LoPy 1.6.x (p23) ? If not ... please do it and then post your results. Have you put BMP180 and read simply the SN ... with LopY/Wipy this is raising I2C errors. With Arduino/PI this is working.
          Have you performed stress tests on your pyboard? Running complex scripts for hours in lab and outside at bad conditions (eq temperature), in transmission mode (frequently Wifi up then down, Lora up then down) loading modules progressively, gc collect, running with free memory around 8-10k ?
          That is a big difference between real IOT stuff and running a sketch with 1-2 sensors on it... where probably Wifi is always ON and the board is running on wall power and not battery/solar.
          C L 2 Replies Last reply Reply Quote 0
            Colateral @robert-hh
            @robert-hh Thanks. We will try it.
              Colateral @Neo
              @Neo I understand your frustration, but let's keep our faith that pycom product development manager is proactive on the enumerated issues.
                livius @Neo
                @Neo
                no i am not from pycom team if you look at history you can find much more criticize post by me ;-)
                https://forum.pycom.io/post/2245
                but i try to change attitude ;-)
                Because much more working now then previously was even possible...
                UPDATE
                I change also attitude because @daniel describe how situation looks like - that they are affected by ESP-IDF development
                about onewire i use this:
                https://github.com/pycom/pycom-libraries/tree/master/examples/onewire
                and it work for me on version 1.5.0 and it write data to direcly connected sdcard (without expansion board) many days
                it is stable. On version 1.6.0.b1 it was broken but day after @daniel fix it and release 1.6.1
                which work continously for me since yesterday and write data throught wifi to my server throught tcp/ip socket
                I can not test on Lopy because i have only 2x Wipy2.0
                First is with 1.5.0 firmware second with 1.6.1
                now memory is to limited to me to write main concept.
                and until more memory will be avaiable i only play with sensers
                Current working scenario is lilke this
                first Wipy retrive data from sensors store it to sdcard and connect to second Wipy (master) and send data packet
                Second Wipy have same sensors and store data but is as master and get data from first.
                After whole packet retrive it change from AP to STA mode and connect to server and send whole data.
                After sended all data it go back to AP.
                And this work for me.
                I try playing with STA+AP mode but without success
                but not played much ..
                N 1 Reply Last reply Reply Quote 1
                • N Offline
                  Neo @daniel
                  @daniel Hello.
                  1. Yes. The code was taken from micropython. You can download from here: https://drive.google.com/open?id=0B2FyGVkp3y9ZZ2plTHNFUFF2WW8
                  2. This we tried.We compiled mpy-cross and generated binary... but that is not working.
                  3. Yes. 1.6.1b1 LoPy.
                  4. Most probably requires fast clock... same fast clock issue we believe is also with DHT22 (not I2C). On the terminal we "I2C bus error" message comming from pycom framework.
                  5. I need to check this with our management.
                    livius @Neo
                    @Neo
                    "I2C bus error"
                    @livius BM180 work also for me (but i have some problems previously and do not test if i still must read first something from i2c e.g. light sensor)
                    I suppose than that problem presists
                    i fix this by first read light sensor (it fix something for me) i do not dig enaught because @daniel say that I2C is still software not hardware.
                    @daniel is this still true I2C still software?
                    • N Offline
                      Neo @livius
                      @livius Thanks. I am also a peaceful guy... but the level of frustration starting to go out from me. My apologies.
                      Than you for your feedback.
                      Onewire libray that we are using IS THE SAME... LOOL. Check it here: https://drive.google.com/file/d/0B2FyGVkp3y9ZZ2plTHNFUFF2WW8/view?usp=sharing
                      WiPy for us is not interesting - We are working only with LoPy that has also what Wipy offers.
                      On LopY we have almost 20 modules and more than 20 sensors implementation. The problem is that an IOT node has at least 8 sensors on it. So if you load that modules one by one, the memory is going to be fast drained... so you need to call gc.collect... an amazing this is not freeing the memory accordingly. SO after data acquisition we start the transmission and we stop it after that. And this doing for hours /days.
                      With 1.6.x the system is HANGING on gc.collect and sometimes on gc.mem_free This was not happen on previous 1.5.0b1.
                      We noticed also that with 1.6.x, if you start and stop WLAN many times, at one moment the OS is rebooted, most probably due to memory management.
                      L 1 Reply Last reply Reply Quote 1
                        livius @Neo
                        @Neo
                        Maybe this is some lopy releated problem
                        Did you tried clear Lopy with only onewire.py and one sensor DS18B20?
                        I have log on every boot of Wipy
                        I have checked in the morning there was no log
                        i also do not see any gaps in data in Firebird database on the server
                        • N Offline
                          Neo @livius
                          @livius Thanks. This solution is definitely not for real deployed systems. I mean we are forced to deploy a light sensor in order to read the temperature. Waste of energy and money.
                          What I2C light sensor are you using for this workarround? We would like to investigate it.
                            livius @Neo
                            @Neo
                            yes, definitely not for real deployed systems but if I2C is still software than maybe still required
                            i use BH1750.
                            • N Offline
                              Neo @livius
                              @livius Yes. One LoPy and one DS1b20... and empty output. As far as I remember this was happen also on Wipy 1.5.1b1 but I will check again
                                Colateral @Pete
                                @Pete said in New firmware release, version 1.6.0.b1:
                                Which different brand of WiFi IoT module are you using?
                                  Pete @Colateral
                                  @Colateral I ordered some of these: LinkIt Smart 7688 at the same time as my WiPys. Similar form factor, but runs OpenWrt, a Linux distro originally developed for customising Linksys routers. They arrived at the start of this week. I haven't even opened the box yet, as I'd like to get the WiPy working if I can - my use case is pretty simple and I'd rather not have to admin a whole Linux if I can just write one Python script instead. From the point of view of attack surface if nothing else. But it's a second basket for my eggs if required.
                                  Pete
                                    livius
                                    @daniel
                                    i still have problem of corruption of files stored throught ftp :(
                                      daniel
                                      We just released new firmware, version 1.6.2.b1. These are the changes:
                                      • Fix issue when trying to send empty strings via sockets.
                                      • Update the ESP-IDF.
                                      • Correct RCZ3 uplink frequency and integers overflow.
                                      • Implement ntp_sync for RTC. Add simple support for timezones. See: https://docs.pycom.io/pycom_esp32/library/machine.RTC.html#machine.rtc.ntp_sync
                                      • Correctly set the DNS server. Also disable and enable the right TCP adapter interface.
                                      Cheers,
                                      Daniel
                                        daniel @livius
                                        I still have problem of corruption of files stored throught ftp :(
                                        @livius Really? We have been testing a lot during the last 2 weeks with large files and the issue seem resolved. Does it happen when you perform file operations in your script while at the same time the FTP server is busy with a transfer?
                                          livius @daniel
                                          @daniel
                                          it is by copy file throught e.g. filezilla and without while true: loop
                                          D 2 Replies Last reply Reply Quote 0
                                            daniel @livius
                                            @livius what's the size of the file?
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 2 / 4
