Send modbus slave data via lorawan
I'm currently starting a project to read Modbus slave data and send it via lorawan to TTN. I combining lorawan with OTAA code with pycom_modbus code , here is my code#!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # import pycom from uModBus.serial import Serial from uModBus.tcp import TCP from network import WLAN from network import LoRa import socket import machine import ubinascii import time #pycom.pybytes_on_boot(False) lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AS923) # create an OTAA authentication parameters, change them to the provided credentials app_eui = ubinascii.unhexlify('70B3D57ED0037CB2') app_key = ubinascii.unhexlify('6CE141489C7DA7312C0523697A7B2F30') # join a network using OTAA (Over the Air Activation) #uncomment below to use LoRaWAN application provided dev_eui lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0) #lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0) # wait until the module has joined the network while not lora.has_joined(): time.sleep(2.5) print('Not yet joined...') print('Joined') # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) # make the socket blocking # (waits for the data to be sent and for the 2 receive windows to expire) s.setblocking(True) ######################### RTU SERIAL MODBUS ######################### uart_id = 0x01 #modbus_obj = Serial(uart_id, pins=('P3','P4')) #default p3 p4 ==> tx1 rx1 #modbus_obj = Serial(uart_id, pins=('P3','P4'), ctrl_pin='P8') modbus_obj = Serial(uart_id, pins=('P10','P14'), ctrl_pin='P20') ###################### READ HOLDING REGISTERS ################## slave_addr=0x01 starting_address=0x25 register_quantity=2 signed=True while True: #read modbus slave data_bit register_value = modbus_obj.read_holding_registers(slave_addr, starting_address, register_quantity, signed) #print('Holding register value: ' + ' '.join('{:#x}'.format(x) for x in register_value)) # send some data #s.send(bytes([0x01, 0x02, 0x03])) s.send(register_value) # make the socket non-blocking # (because if there's no data received it will block forever...) s.setblocking(False) # get any data received (if any...) data = s.recv(64) #print(data) time.sleep(120)I got an error message like this,
I don't know yet how to send the data, because I'm a newbie in python.
@Gusti-Made-Arya-Wijaya I've fixed this problem, basically, data from Modbus Slave is byte HEX, so I think to not use conversion function in serial.py.
and here is the result, TTN receive HEX data from lopy4
Thanks all for the replies
This works for me.
LoRaSock.send(bytes([0x01, 0x02])+pack('>h',nvvar['Level']&0xffff)+bytes([0x02, 0x02])+pack('>h',nvvar['Batt']&0xffff))are my variables.
@kjm I think for OTAA mode is no problem. the problem is how to convert the register value to byte
@tuftec data type of register_value is a tuple with int value (17109, 20578), I've tried s.send(bytes(register_value)) but still error. I don't know how to convert the value to byte
Not sure exactly what line corresponds to line 71, but I suspect it is the s.send(register_value) line.
I think you just need to change the type to bytes. Just try s.send(bytes(register_value)).
I have no luck with OTA mode on TTN for the lopy4, but ABP works OK
