    Cannot join using OTAA using AU915
    6 Posts 3 Posters 107 Views 3 Watching
    • snorkmanS Offline
      snorkman
      Greetings from Argentina :-)
      I had my code working fine when I was working in EU and with TTN for months. Now I moved to this side of the globe and therefore had to re configure my LoPy’s firmware.
      My main issue right now is that the node never goes beyond the activation, it is always prompting:
      My GW is a Dragino LG308 multichannel. Do you see anything wrong in the config?
      and my code running on the LoPy looks like
      from network import LoRa
      import ubinascii
      adc = machine.ADC()
      # create an OTAA authentication parameters
      APP_EUI = ubinascii.unhexlify('bbbbbbb')
      APP_KEY = ubinascii.unhexlify('aaaaaaaaa')
      def enter_deepsleep(interval=1):
          lora.nvram_save()
          print("Deep Sleeping for {0} minutes".format(interval))
          machine.deepsleep(interval * 60000)
          print("AWAKE!!! entering normal operation mode")
      def connect_to_ttn(lora_object):
          """Receives a lora object and tries to join"""
          # join a network using OTAA (Over the Air Activation)
          lora_object.join(activation=LoRa.OTAA, auth=(APP_EUI, APP_KEY), timeout=0)
          # wait until the module has joined the network
          while not lora_object.has_joined():
              print('Not yet joined...')
              pycom.rgbled(0xff0000)
      def get_supercap_voltage():
          samples = []
          supercap_pin = adc.channel(pin='P13', attn=adc.ATTN_11DB)   #analog pin on P13
          for sample in range(20):
              val = supercap_pin()# read an analog value
              samples.append(val)
              time.sleep_ms(1)
          average = sum(samples)/len(samples)
          return average
      def compress_analog_reading_payload(mediciones):
           payload = 0
           tribble_shifts = len(mediciones) - 1
           for medicion in mediciones:
               payload = payload | (medicion << (12 * tribble_shifts))
               tribble_shifts -=1
           return(payload)
      # Initialise LoRa in LORAWAN mode.
      # United States = LoRa.US915
      #lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU=915)
      for index in range(0, 8): lora.remove_channel(index)
      for index in range(16, 65): lora.remove_channel(index)
      for index in range(66, 72): lora.remove_channel(index)
      lora.nvram_restore() #if there is nothing to restore it will return a False
      if not lora.has_joined():
          connect_to_ttn(lora)
          print("CONNECTED!!")
          pycom.rgbled(0x00ff00)
          lora.nvram_erase()
      # create a LoRa socket
      # set the LoRaWAN data rate
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
      # make the socket blocking
      # (waits for the data to be sent and for the 2 receive windows to expire)
      #s.setblocking(True)
      # send some data
      while lora.has_joined():
          supercap_voltage = int(get_supercap_voltage())
          s.setblocking(True)
          payload = compress_analog_reading_payload([1700, 1000, 2800, 300, supercap_voltage])
          payload_in_bytes = list(payload.to_bytes(8, 'big'))
          s.send(bytes(payload_in_bytes))
      #(because if there's no data received it will block forever...)
          s.setblocking(False)
      # get any data received (if any...)
          data = s.recv(64)
          if data:##print(data)
              time.sleep(0.5)
              time.sleep(0.5)
              pycom.rgbled(0x0000ff)
              time.sleep(0.5)
          print(data)
          enter_deepsleep(5)
      and the firmware running on the LoPy:
      >>> os.uname()
      (sysname='LoPy4', nodename='LoPy4', release='1.20.2.r2', version='v1.11-3a7776d on 2020-11-23', machine='LoPy4 with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.6.1')
      Am I doing something wrong?
        From your TTN logs, it seems the gateway is receiving a join request (yellow lightning bolt), and sending out a join accept (green lightning bolt). And that seems to work fine! Also the time difference (4 seconds) is similar to what Im getting here. I dont actually know if the message is sent out (maybe you can look at the terminal of the dragino gateway?). Also, verify the settings with the settings mentioned here: https://github.com/TheThingsNetwork/gateway-conf/blob/master/AU-global_conf.json
        In your code, I found a typo here: lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU=915) at AU=915. Other than that, I cant really tell anything wrong.
        snorkmanS 1 Reply Last reply Reply Quote 0
          robert-hh @snorkman
          @snorkman Which TTN router do you use? There were posts here telling that the Australian router was very slow. Maybe you could try other routers.
          snorkmanS 2 Replies Last reply Reply Quote 0
          • snorkmanS Offline
            snorkman @robert-hh
            @robert-hh I was using the default one for Australia. Iwill try with a different on and keep you posted.
            • snorkmanS Offline
              snorkman @Gijs
              @Gijs yeah that was a typo when I did C&P.
              I am using a Dragino LG308
              • snorkmanS Offline
                snorkman @robert-hh
                @robert-hh
                It seems like a firmware upgrade on the LG308 did the job.
                The code is working fine and I can successfully join the network without retrials.
                Thanks!
