Correction to pinout in PySense2X_specsheet.pdf version 1.0
I think the pinout for the 'J4' external IO Header in the pinout diagram is not correct. It is basically the numbering of the pins of the 10-pin header that is wrong. And the pinout lacks information about which pins of the pycom module the 10-pin header is connected to. I made corrections on the following exert from the specsheet:
This has been corrected in the version here: https://docs.pycom.io/datasheets/expansionboards/pytrack2/, and also in the pdf datasheet linked in on that page.Gijs
Thanks very much!
Jan
