LoPy crashes under 'heavy load'
  • When looping (while true) the device nearly instantly dies:
    Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
    Register dump:
    PC : 400e6692 PS : 00060a30 A0 : 800e5104 A1 : 3ffd4ad0
    A2 : 00000000 A3 : 00000000 A4 : 00000bed A5 : 3ffbd4ac
    A6 : 00000bec A7 : 3ffb15d0 A8 : 00000000 A9 : 00000000
    A10 : 3ffb2480 A11 : 00000000 A12 : 00000010 A13 : 000000eb
    A14 : 00000000 A15 : 00000001 SAR : 0000001a EXCCAUSE: 0000001c
    EXCVADDR: 00000000 LBEG : 4000c2e0 LEND : 4000c2f6 LCOUNT : ffffffff
    Rebooting...
    ets Jun 8 2016 00:22:57
    Having a sleep solves it a little, but it needs to much sleeps (1s) to correctly work, but if you want to listen to the radio packets thats not very handy
  • i can confirm the issue seems to be resolved
  • Hello,
    We are aware of this issue (it's related to the garbage collector), and it was solved a couple of days ago. A fix will be available on the next release.
    Cheers,
    Daniel
