    lopy4 +pytrack v1.1 does not show me coordinates , i have not idea why. the code stops in this part.
    7 Posts 4 Posters 56 Views 4 Watching
      jefferson ayala
        jcaron @jefferson ayala
        @jefferson-ayala please share your code (be sure to format is as code by clicking on the </> icon on the toolbar). Also include the full log (as text, not an image).
        Also, are you outside with good visibility of the sky? A GPS receiver needs line-of-sight to multiple GPS satellites.
        You may want to disable Pybytes if you don't use it, it can be quite confusing.
          jefferson ayala @jcaron
          @jcaron hi , i share the code , i was download at github , please help me. the picture shared was outside of my house , do you know how i know if my zone o where a found a good visibility ? have you ever used the gps with the pytrack ?please .Help me ```
          code_text
          Insert Code Here
          ```## Test code for read date/time from gps and update RTC
          import math
          import network
          import os
          import utime
          from machine import RTC
          from machine import SD
          from machine import Timer
          from L76GNSS import L76GNSS
          from pytrack import Pytrack
          import struct
          # setup as a station
          import gc
          time.sleep(2)
          gc.enable()
          #Start GPS
          py = Pytrack()
          l76 = L76GNSS(py, timeout=30)
          #start rtc
          rtc = machine.RTC()
          print('Aquiring GPS signal....')
          #try to get gps date to config rtc
          while (True):
             gps_datetime = l76.get_datetime()
             #case valid readings
             if gps_datetime[3]:
                 day = int(gps_datetime[4][0] + gps_datetime[4][1] )
                 month = int(gps_datetime[4][2] + gps_datetime[4][3] )
                 year = int('20' + gps_datetime[4][4] + gps_datetime[4][5] )
                 hour = int(gps_datetime[2][0] + gps_datetime[2][1] )
                 minute = int(gps_datetime[2][2] + gps_datetime[2][3] )
                 second = int(gps_datetime[2][4] + gps_datetime[2][5] )
                 print("Current location: {}  {} ; Date: {}/{}/{} ; Time: {}:{}:{}".format(gps_datetime[0],gps_datetime[1], day, month, year, hour, minute, second))
                 rtc.init( (year, month, day, hour, minute, second, 0, 0))
                 break
          print('RTC Set from GPS to UTC:', rtc.now())
          chrono = Timer.Chrono()
          chrono.start()
          #sd = SD()
          #os.mount(sd, '/sd')
          #f = open('/sd/gps-record.txt', 'w')
          while (True):
             print("RTC time : {}".format(rtc.now()))
             coord = l76.coordinates()
             #f.write("{} - {}\n".format(coord, rtc.now()))
             print("$GPGLL>> {} - Free Mem: {}".format(coord, gc.mem_free()))
             coord1 = l76.coordinates1()
             print("$GPGGA>> {} - Free Mem: {}".format(coord1, gc.mem_free()))
             coord2 = l76.get_datetime()
             print("$G_RMC>> {} - Free Mem: {}".format(coord2, gc.mem_free()))
            @jefferson-ayala I believe you have other code running on your LoPy, the output does not match tour source. Do you have something in boot.py maybe?
              @jcaron hi , i have another part of the code . watch it
              code_textfrom machine import UART
              from network import Sigfox
              import binascii
              import os
              # initalise Sigfox for RCZ1 (Europe) (You may need a different RCZ Region)
              sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4)
              # print Sigfox Device ID
              print("ID: ", binascii.hexlify(sigfox.id()))
              # print Sigfox PAC number
              print("PAC: ", binascii.hexlify(sigfox.pac()))
              uart = UART(0, baudrate=115200)
              os.dupterm(uart)
              machine.main('main.py')
                You set a timeout of 60 in the main.py (which is differnet in the code you shared, where it is 30) on instantiating the GPS, meaning it will only print results every 60 seconds. Also, as @jcaron suggested, have you tried (and uploaded) the source from our examples on Github / in the documentation: https://docs.pycom.io/tutorials/expansionboards/pytrack2/ ?
                  crumble @jefferson ayala
                  @jefferson-ayala
                  I am not on the latest version.
                  It seems that main.py is never called.
                  outcomment the last 3 lines of boot.py. You do not need to set the UART and main.py to the default values. Once this was problematic. Especially the UART redefinition.
                  If main.py is called, you are waiting for at least one satellite to go on. This may never happens. Sadly there is no flush. You can either set to LED color or a sleep of 4sec after each print. So you can see better the last executed instruction .
