Latest Sqnsupdate UART upgrade not working 1.20.2.r4
  • Hello upgrade via (PC) UART is not working on Linux.
    As DOCS said, I downloaded last sqmsupgrade from https://github.com/pycom/pycom-libraries/tree/master/lib/sqnsupgrade
    I upgraded the board with pycom tool to 1.20.2.r4
    After fresh/power plug, I got the following...
    On GPY (with ExpansionBoard 3.0)
    Connecting to /dev/ttyACM1...
    ets Jun  8 2016 00:22:57
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2128
    load:0x4009fa00,len:19760
    entry 0x400a05bc
    Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; GPy with ESP32
    >>> import sqnsupgrade
    >>>> sqnsupgrade.uart(True,debug=True)
    ><<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
    >>>> GPy with firmware version 1.20.2.r4
    >The current delay is 1000
    >Response (+++ #1): None
    >Response (AT #1) None
    >Response (AT #3) None
    >Response (AT #4) None
    >Response (AT #1 @ 115200) None
    >Response (AT #2 @ 115200) b'\xfe\xfd\xfe\xfe\xfe\xfe\xfe\xfe\xfe'
    >The current delay is 2000
    >Response (AT #1) b'\r\nERROR\r\n'
    >Response (AT #2) b'\r\nOK\r\n'
    >Response (AT+SMOD?) b'\r\n2\r\nOK\r\n'
    >Converting response: 2 to int...
    >Modem state: 2
    >Preparing modem for upgrade...
    >Checking bootrom & application
    >Checking line
    >Checking line SYSTEM VERSION
    >Checking line ==============
    >Checking line   FIRMWARE VERSION
    >Checking line     Bootloader0  : 5.1.1.0 [41065]
    >old_br: False
    >Checking line     Bootloader1* : 6.0.0.0 [41019]
    >Checking line     Bootloader2  : 5.1.1.0 [41065]
    >Checking line     NV Info      : 1.1,0,0
    >Checking line     Software     : 6.0.0.0 [41019] by robot-soft at 2018-12-13 21:41:15
    >old_sw: False
    >Checking line     UE           : 6.0.0.0
    >Checking line   COMPONENTS
    >Checking line     ZSP0         : 1.0.99-3171
    >Checking line     ZSP1         : 1.0.98-3170
    >Checking line
    >Checking line OK
    >Checking line
    >Returning: False
    >FFH mode is not necessary... ignoring!
    >Do not specify updater.elf when updating!
    >mirror? True  recover? False  resume? True  direct? False  atneg_only? False bootrom? False load_fff? False
    >baudrate: 921600 target_baudrate: 921600
    >Initial prepartion complete...
    >Attempting AT wakeup... [921600]
    >b'\r\nOK\r\n'
    >Entering recovery mode
    >AT+SMOD? returned 2
    >Going into MIRROR mode... please close this terminal to resume the upgrade via UARTakeup**
    I closed the Atom them I continued in python3 terminal
    >>> import sqnsupgrade
    >>> sqnsupgrade.run('/dev/ttyACM1','../NB1-41019/NB1-41019.dup',debug=True)
    File ../NB1-41019/NB1-41019.dup has size 5835531
    mirror? False  recover? False  resume? False  direct? False  atneg_only? False bootrom? False load_fff? True
    Setting port /dev/ttyACM1
    Setting baudrate to 921600
    Loading ../NB1-41019/NB1-41019.dup
    Firmware file is too big to load via FFF method. Using ON_THE_FLY
    b''
    count=1
    Seems that is a Serial issue (read/write) from modem to UART1 (/tty/ACM1)
    That AT 'OK' seems that is received tooo fast and not forwarded to UART1 (/tty/ACM1)
    Any idea how to fix this?
    Please note that is working update with SD card... but I need UART upgrade because we have our own G01 boards without SDCard
  • From what I could find in this time, it seems to be related to the CEREG setting of the LTE modem, which was changed in r2. If we use (temporarily)
    from network import LTE
    lte = LTE()
    lte.send_at_cmd('AT+CEREG=2')
    I can get the sqnsupgrade to work over UART.
    Let me know if that works for you!
  • Im able to reproduce the issue. Haven't done a lot of updating with LTE over the last few weeks so didnt come across it yet. I'll try to track it down, but it appears to be broken on r2 and r3 as well. r1 works fine for me, so if it is possible for you to use that in the meantime? Sorry for the inconvenience
