    Where is `rgbled` function in code?
    5 Posts 3 Posters 77 Views 3 Watching
    • M Offline
      Matthew Felgate
      Where is rgbled defined in the source code?
      I would like to read a little of how the function works behind the scenes.
        You can find it here: https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modpycom.c#L159
        All source code for the modules you can import can be found in the mods folder.
        Best,
          robert-hh @Matthew Felgate
          @Matthew-Felgate In addition to the place @Gijs mentioned in the files modled.c and modled.h in the mods folder.
          • M Offline
            Matthew Felgate
            Could you edit it so that you could do things like rgbled('red'), rgbled('blue'), rgbled('yellow') etc?
            You could allow webcolors and just translate to hexcodes behind the scenes.
              @Matthew-Felgate The question then would be, which web colour set to use. Thus I consider it sufficient as it is. You can always make s little Python module wich defines the color names and reuse that, e.g.
              WHITE = const(0xffffff)
              RED = const(0xff0000)
              # and so on
