    Guru Meditation Error: Core 1 panic'ed (LoadProhibited) on WiPy 3.0
    3 Posts 2 Posters 84 Views 2 Watching
      Sebastian San Martin
      Hi everyone, i just got a pack of brand new wipys 3.0 with an expansion board 3.0. I was going through some of the tutorials and got a Guru Meditation Error when trying to set the board on deepsleep mode. I used the exact same little code showed on the webpage i linked before:
      print("Wake up")
      machine.deepsleep(1000) #deepsleep 1 second
      print("this will never get printed!")
      Here's the output on REPL (i used VScode with Pymkr extension on ubuntu 20.04, i also updated the wipy's firmware to last version):
      Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
      Core 1 register dump:
      PC      : 0x400ff1ba  PS      : 0x00060b30  A0      : 0x800e7e5b  A1      : 0x3ffd7020
      A2      : 0x00000000  A3      : 0x00000001  A4      : 0x00000000  A5      : 0x00000009
      A6      : 0x00008000  A7      : 0x8000ffff  A8      : 0x3f40f028  A9      : 0x3ffd6ff0
      A10     : 0x00000000  A11     : 0x00000000  A12     : 0x3ff56960  A13     : 0x00000000
      A14     : 0x3ffdcd30  A15     : 0x00000001  SAR     : 0x0000001e  EXCCAUSE: 0x0000001c
      EXCVADDR: 0x00000000  LBEG    : 0x400eccc0  LEND    : 0x400ecd03  LCOUNT  : 0x00000000
      Backtrace: 0x400ff1ba:0x3ffd7020 0x400e7e58:0x3ffd7040 0x400e5748:0x3ffd7060 0x4010186a:0x3ffd7090 0x400fdbf9:0x3ffd70c0 0x400fdc89:0x3ffd70e0 0x40109c57:0x3ffd7100 0x40101904:0x3ffd71a0 0x400fdbf9:0x3ffd7200 0x400fdc26:0x3ffd7220 0x400e12d9:0x3ffd7240 0x400e1425:0x3ffd72e0 0x400dfffe:0x3ffd7310
      Rebooting...
      ets Jun  8 2016 00:22:57
      rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2128
      load:0x4009fa00,len:19760
      entry 0x400a05bc
      If there's anyone who might have an idea of how to solve this i would really aprecciate it, i really need this feature for my project to work. Thank you all.
        Have you tried clearing the NVS and CONFIG partitions together with the flash on the device using hte firmware updater tool (the options are listed in the advanced section). (Un)fortunately, I cannot reproduce the issue on the latest firmware, 1.20.2.r4
        Best,
          That worked flawlessly! Thank u so much!
