    pyscan paper ink
    23 Posts 2 Posters 104 Views 3 Watching
      gael cobert
      hello
      i want to use this paper ink hat with my pyscan
      https://www.waveshare.com/wiki/E-Paper_Driver_HAT
      is it possible to connect it to the pyscan ?
      https://docs.pycom.io/gitbook/assets/pyscan-pinout.pdf
      where must i connect the pin ?
      3.3V ->
      GND -->
      DIN -->
      CLK -->
      CS -->
      DC -->
      RST -->
      BUSY
      and do you know a micropython library for this HAT ?
      thanks
        robert-hh @gael cobert
        @gael-cobert User mcauser invests a lot of time in drivers for displays. Even when made for the micropython.org dialect, they should either work or be easy to adapt. see:
        https://github.com/mcauser/micropython-waveshare-epaper
        Edit: The one I tested worked instantly
          gael cobert
          ok thanks ! do you know how can i connect the HAT to the pyscan ?
            @gael-cobert That depends. Pyscan makes heavy use of the Pins. And depending on the module used, even more pins are blocked. You can use all available pins.
            3.3V -> 3.3V, e.g. at the Fingerprint sensor block
            GND --> GND e.g. at the Fingerprint sensor block
            DIN --> P19 at the fingerprint sensor
            CLK --> e.g. P9
            CS --> May be tied to GND, if you just connect one device
            DC --> e.g. P10
            RST --> e.g. P2, which is shared with the RGB led. You may also connect it to Reset. Then the display is reset wehn you push the butto.
            BUSY -> P15 at the fingerprint sensor
            G 1 Reply Last reply Reply Quote 1
              gael cobert @robert-hh
              @robert-hh hello thanks
              when i start the program i have this error
              File "<stdin>", line 33, in <module>
              ValueError: invalid argument(s) value
              line 33 is : miso = Pin(19)
              SPIV on ESP32
              sck = Pin(18)
              miso = Pin(19)
              mosi = Pin(23)
              dc = Pin(32)
              cs = Pin(33)
              rst = Pin(19)
              busy = Pin(35)
              spi = SPI(2, baudrate=20000000, polarity=0, phase=0, sck=sck, miso=miso, mosi=mosi)
                @gael-cobert In the Pycom world ĥave to write
                sck = "P18"
                miso = "P19"
                mosi = "P23"
                and then
                spi = SPI(2, baudrate=20000000, polarity=0, phase=0, pins=(sck, mosi, miso))
                You have to use either the Pxx numbers of the development board, or the Gxx numbers of the expansion board, but NEVER the GPIO numbers of the ESP32.
                See: https://docs.pycom.io/firmwareapi/pycom/machine/spi/ and
                https://docs.pycom.io/firmwareapi/pycom/machine/pin/#app
                  @robert-hh said in pyscan paper ink:
                  miso = "P19"
                  ok thanks !
                  this is a picture of the board / HAT and pin
                  https://drive.google.com/file/d/11vN_3IOCtbFyNRU48OogThDfdZR2UpcA/view
                  can you confirm miso = "P19"
                  what is miso and mosi ? because i have DIN, CLK, CS, DC etc
                  the new code :
                  # SPIV on ESP32
                  sck = "P18"
                  miso = "P19"
                  mosi = "P23"
                  #dc = Pin(10)
                  #cs = Pin(33)
                  #rst = Pin(2)
                  #busy = Pin(15)
                  and the error is now
                    File "<stdin>", line 18, in <module>
                  OSError: resource not available
                    @gael-cobert Probing it with amultimeter it turns out, that the P15 and P19 at lower column, where you connectef the blue and lilac cable, are not connected to the socket for the xxPy module. However, the P15 amd P19 labeled pins at the upper socket, where you connected the green and yellow cable, are connected.
                    Also: you have to connect mosi to din of the pyper ink, not miso. miso is actually not used at all, so you can select e.g. p13 for it.
                      ok thanks
                      this this a photo of the corrected pin
                      https://drive.google.com/file/d/121qPyq86FyFCAwZgKOXwRSW4PqKHniux/view?usp=drivesdk
                      i connected RESET pin in P11 --> https://drive.google.com/file/d/126aoKHjdVRYbr9yN0W114HpItaYDK5zA/view?usp=drivesdk
                      i don't know what is "mosi" and "miso"
                      i have din ( blue cable) connected to P19
                      so din must be connected to P13 or P19 ?
                        @gael-cobert It's easy to remember once you heard it:
                        mosi = Master Out Slave In
                        miso = Master In Slave Out
                        The connection looks OK.
                        G 2 Replies Last reply Reply Quote 0
                          @robert-hh
                          ok this is the setup code
                          rst = Pin('P11') --> ok ( white ) --> https://drive.google.com/file/d/126aoKHjdVRYbr9yN0W114HpItaYDK5zA/view?usp=drivesdk
                          dc = Pin('P10') --> ok ( green )
                          busy = Pin('P15') --> ok ( lilac )
                          cs = Pin('???') --> KO ( orange ) ?? connected to GND --> must i type Pin('GND')
                          clk = Pin('P9') --> ok ( yellow )
                          mosi = Pin('???') --> ????? don't understand --> i have no cable ...
                          spi = SPI(2, baudrate=20000000, polarity=0, phase=0, pins=(sck, mosi, None))
                            @robert-hh
                            mosi = DIN = Pin('P15') --> blue cable
                              @gael-cobert
                              since you have connected the cs pin of the device to GND, you can skip it in your code. I recommended that to save port pins. It requires howerver to change the code.
                              mosi is the pin for DIN of the display, used to send data to the display. So you have that connected to P19.
                              The SPI signal which you do not need is miso, because no data is read back from the display.
                                ok thanks it seems ok so now i have this error :
                                  File "main.py", line 76, in <module>
                                  File "/flash/lib/epaper7in5.py", line 135, in display_frame
                                IndexError: bytearray index out of range
                                	Example for 4.2 inch black & white Waveshare E-ink screen
                                	Run on ESP32
                                import epaper7in5
                                from machine import Pin, SPI
                                # SPIV on ESP32
                                rst = Pin('P11')
                                dc = Pin('P10')
                                busy = Pin('P15')
                                cs = Pin('P4')
                                clk = Pin('P9')
                                mosi = Pin('P15')
                                spi = SPI(0, mode=SPI.MASTER, baudrate=2000000, polarity=0, phase=0, pins=(clk, mosi, None))
                                e = epaper7in5.EPD(spi, cs, dc, rst, busy)
                                e.init()
                                w = 600
                                h = 384
                                x = 0
                                y = 0
                                # use a frame buffer
                                # 400 * 300 / 8 = 15000 - thats a lot of pixels
                                import framebuf
                                buf = bytearray(w * h // 8)
                                fb = framebuf.FrameBuffer(buf, w, h, framebuf.MONO_HLSB)
                                black = 0
                                white = 1
                                fb.fill(white)
                                # write hello world with black bg and white text
                                from image_dark import hello_world_dark
                                from image_light import hello_world_light
                                print('Image dark')
                                #bufImage = hello_world_dark
                                #fbImage = framebuf.FrameBuffer(bufImage, 128, 296, framebuf.MONO_HLSB)
                                #fb.blit(fbImage, 20, 2)
                                #bufImage = hello_world_light
                                #fb.blit(fbImage, 168, 2)
                                #e.display_frame(buf)
                                # write hello world with white bg and black text
                                print('Image light')
                                #e.display_frame(hello_world_light)
                                print('Frame buffer things')
                                fb.fill(white)
                                fb.text('Hello World',30,0,black)
                                #fb.pixel(30, 10, black)
                                #fb.hline(30, 30, 10, black)
                                #fb.vline(30, 50, 10, black)
                                #fb.line(30, 70, 40, 80, black)
                                #fb.rect(30, 90, 10, 10, black)
                                #fb.fill_rect(30, 110, 10, 10, black)
                                #for row in range(0,36):
                                #	fb.text(str(row),0,row*8,black)
                                #fb.text('Line 36',0,288,black)
                                # wrap text inside a box
                                black = 0
                                white = 1
                                # clear
                                fb.fill(white)
                                # display as much as this as fits in the box
                                str = 'Lorem ipsum dolor sit amet, consectetur adipiscing elit. Etiam vel neque in elit tristique vulputate at et dui. Maecenas nec felis lectus. Pellentesque sit amet facilisis dui. Maecenas ac arcu euismod, tempor massa quis, ultricies est.'
                                # this could be useful as a new method in FrameBuffer
                                def text_wrap(str,x,y,color,w,h,border=None):
                                	# optional box border
                                	if border is not None:
                                		fb.rect(x, y, w, h, border)
                                	cols = w // 8
                                	# for each row
                                	j = 0
                                	for i in range(0, len(str), cols):
                                		# draw as many chars fit on the line
                                		fb.text(str[i:i+cols], x, y + j, color)
                                		j += 8
                                		# dont overflow text outside the box
                                		if j >= h:
                                			break
                                # clear
                                fb.fill(white)
                                # draw text box 1
                                # box position and dimensions
                                print('Box 1')
                                bx = 8
                                by = 8
                                bw = 112 #  = 14 cols
                                bh = 112 #  = 14 rows (196 chars in total)
                                text_wrap(str,bx,by,black,bw,bh,black)
                                # draw text box 2
                                print('Box 2 & 3')
                                bx = 0
                                by = 128
                                bw = w # 128 = 16 cols
                                bh = 6 * 8 # 48 = 6 rows (96 chars in total)
                                # draw text box 3
                                bx = 0
                                by = 184
                                bw = w//2 # 64 = 8 cols
                                bh = 8 * 8 # 64 = 8 rows (64 chars in total)
                                text_wrap(str,bx,by,black,bw,bh,None)
                                  @gael-cobert You have set MOSI to P15. That's not possible. and in fact you use P19
                                    @gael-cobert In the epaper driver the dimension is set to 640x384, in your control code you use 600x384. These two setting must match.
                                      @robert-hh
                                      yes thanks
                                      i checked the screen model
                                      i have this one : 5.83inch-e-paper (waveshare website 640x480)
                                      so
                                      i changed the driver for : epaper5in83 (600x448)
                                      but now i have this error
                                      File "<stdin>", line 60, in <module>
                                      File "/flash/lib/epaper5in83.py", line 136, in display_frame
                                      	Run on ESP32
                                      import epaper5in83
                                      # SPIV on ESP32
                                      rst = Pin('P11')
                                      dc = Pin('P10')
                                      busy = Pin('P15')
                                      cs = Pin('P4')
                                      clk = Pin('P9')
                                      mosi = Pin('P19')
                                      e = epaper5in83.EPD(spi, cs, dc, rst, busy)
                                      e.init()
                                      w = 600
                                      h = 448
                                      x = 0
                                      y = 0
                                      import framebuf
                                      black = 0
                                      white = 1
                                      fb.fill(white)
                                      print('Image dark')
                                      fb.fill(white)
                                      black = 0
                                      white = 1
                                      # clear
                                      fb.fill(white)
                                      	cols = w // 8
                                      	# for each row
                                      	j = 0
                                      		j += 8
                                      		if j >= h:
                                      			break
                                      # clear
                                      fb.fill(white)
                                      # draw text box 1
                                      print('Box 1')
                                      bx = 8
                                      by = 8
                                      # draw text box 2
                                      print('Box 2 & 3')
                                      bx = 0
                                      by = 128
                                      # draw text box 3
                                      bx = 0
                                      by = 184
                                        @robert-hh
                                        hello i have another 4.2 paper ink screen (WFT0420CZ15)
                                        so i changed the driver and the resolution (400x300), no more error but the screen do not respond / change :p
                                        	Run on ESP32
                                        import epaper4in2
                                        # SPIV on ESP32
                                        rst = Pin('P11')
                                        dc = Pin('P10')
                                        busy = Pin('P15')
                                        cs = Pin('P4')
                                        clk = Pin('P9')
                                        mosi = Pin('P19')
                                        e = epaper4in2.EPD(spi, cs, dc, rst, busy)
                                        e.init()
                                        w = 400
                                        h = 300
                                        x = 0
                                        y = 0
                                        import framebuf
                                        black = 0
                                        white = 1
                                        fb.fill(white)
                                        #from image_dark import hello_world_dark
                                        #from image_light import hello_world_light
                                        print('Image dark')
                                        fb.fill(white)
                                        black = 0
                                        white = 1
                                        # clear
                                        fb.fill(white)
                                        	cols = w // 8
                                        	# for each row
                                        	j = 0
                                        		j += 8
                                        		if j >= h:
                                        			break
                                        # clear
                                        fb.fill(white)
                                        # draw text box 1
                                        print('Box 1')
                                        bx = 8
                                        by = 8
                                        # draw text box 2
                                        print('Box 2 & 3')
                                        bx = 0
                                        by = 128
                                        # draw text box 3
                                        bx = 0
                                        by = 184
                                          @robert-hh
                                          if i skip cs in the code,
                                          how can i init : e = epaper4in2.EPD(spi,cs , dc, rst, busy)
                                          because it needs "cs" ....
                                            @gael-cobert said in pyscan paper ink:
                                            clk = Pin('P9')
                                            mosi = Pin('P19')
                                            No sign of life at all? no flickering? Check the wiring again.
                                            I use the SPI constructor usually with the Pin names instead of Pin objects. That would then be:
                                            clk = "P9"
                                            mosi = "P19"
                                            There are switches on the HAT. Did you set them accordingly. You are using the 4 wire SPI mode. And the display config switch must be at B.
                                            • 1
                                            • 2
                                            • 1 / 2
