LOPY4 Nano-Gateway connect third party LoRa node
I am trying to connect a Dragino LHT65 sensor to the TTN through the LOPY4 nano gateway. Seems like the nano gate way is not picking up anything from this node. Has anybody tried to use a non-Pycom node to connect to the TTN using the LOPY4 nano gateway?
@rcolistete Yes it works, Thanks. By the way the following is the correct link to the LHT65 documentation:
The single channel instructions are on page 36
LoPy4 nanogateway is a single channel one.
So all the LoRaWan nodes need to have the same channel configuration to communicate with it.
See the LHT65 documentation about "Single Channel Mode".
