    'module' object has no attribute 'BH1750FVI'
    4 Posts 3 Posters 22 Views 3 Watching
      sung-pil kim 0
      hi~
      In web page(https://docs.pycom.io/tutorials/hardware/i2c/),
      When I run code main.py, AttributeError : 'module' object has no attribute 'BH1750FVI'
      The files, bh1750fvi.py and main.py are saved in same folder.
      What I check? please~
      • M Offline
        Matthew Felgate 0 Global Moderator
        Hi Sung-Pil Kim
        I have just checked this myself and it appears to import. Is the file bh1750fvi.py definitely uploaded to the board?
        May I check which board and expansion board are you using.
        Kind Regards
        Matthew
          livius
          @sung-pil-kim-0:
          you must tell us more basic informations like hardware used and other thigs. Foto of setup will be also helpfull.
          how do you run the code?
            sung-pil kim 0 @livius
            @livius Thank you very much for your answer.
            I have WiPy 3.0 and Expansion board 3.0. I 'run' the code(run button click)
            Today(2021-02-19) I uploaded the code(main.py and bh1750fvi.py).
            It works!!
            Thank you.
