    Lopy4 LoraWAN Uplink Device Rejoin Command
    4 Posts 2 Posters 75 Views 2 Watching
      Adam Forbes
      Hello, I am working with a Lopy4 module using LoraWAN capabilities.
      I would like to remotely trigger the Lopy4 to do a network rejoin.
      Can you let me know is there a command I can send to the device over TTN network uplink so that the device will initiate a rejoin?
        thinginnovations
        You can always use a custom downlink message to trigger a re-join.
        Andrew
          Adam Forbes
          Cheers Andrew. To clarify a bit more - this is for devices already deployed in the field. SO I do not have the ability to modify the PyCom.
          I'm wondering if the Lopy4 has pre-built LoRa downlink commands built in. And if yes is there a guide on what these are and how to send them?
            thinginnovations
            Nothing built in, you'd have to update the code to implement this, which you say is not possible.
            Andrew
