    Can't connect to TTN with LoPy4 as Nanogateway
    8 Posts 3 Posters 23 Views 3 Watching
      davorin
      Good afternoon
      Using the nanogateway example and filled out config.py with my gateway settings from TTN...
      When starting LoPy4 running 1.20.2.r4 it says it is connected to the TTN network:
      entry 0x400a05bc
      [     2.635] Starting LoRaWAN nano gateway with id: b'30AEA4FFFE74C1B8'
      [     3.949] WiFi connected to: TammiSiech
      [     3.958] Syncing time with ch.pool.ntp.org ...
      [3121410.370] RTC NTP sync complete
      [3121410.370] Opening UDP socket to eu.thethings.network (52.169.76.255) port 1700...
      [3121410.370] Setting up the LoRa radio at 868.1 Mhz using SF7BW125
      [3121410.370] LoRaWAN nano gateway online
      [3121410.370] You may now press ENTER to enter the REPL
      But in the TTN console I still see no connection....and yes..the gateway was set up with the legacy packet forwarder...
      Any ideas what might be still misconfigured?
      But then I still have after few minutes a core dump:
      >>> Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
      Core 1 register dump:
      PC      : 0x4010a8bb  PS      : 0x00060230  A0      : 0x800e0ff8  A1      : 0x3ffd9150
      A2      : 0x00000001  A3      : 0x00000001  A4      : 0x00000000  A5      : 0x00000001
      A6      : 0x00000000  A7      : 0xff000000  A8      : 0x80109706  A9      : 0x3ffe73e0
      A10     : 0x00000001  A11     : 0x00000001  A12     : 0x3f94f110  A13     : 0x3f94f110
      A14     : 0x3ffe7570  A15     : 0x3ffe74d0  SAR     : 0x0000001c  EXCCAUSE: 0x0000001c
      EXCVADDR: 0x00000001  LBEG    : 0x40094230  LEND    : 0x4009425e  LCOUNT  : 0xffffffff
      Backtrace: 0x4010a8bb:0x3ffd9150 0x400e0ff5:0x3ffd9170 0x400e1066:0x3ffd9190 0x400e1585:0x3ffd91c0 0x400e17f7:0x3ffd91e0 0x400e0199:0x3ffd9220
      QCABAAEAAAASAAAAbAEAAA==
      qDz+P5CQ/T9wd/4/
      IHP+PxB3/j8yfQkA8EL8P/BC/D+oPP4/6EL8Pw4AAAC8lfw/vJX8P6g8/j8AAAAA
      CwAAAHRj/j9NUFRocmVhZAAAAB4LC5gAAQAAAHB3/j8AAAAAIAIGAAUAAAABAAAA
      AAAAAKx2/j8AAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
      IopAPwAAAABUUQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
      thanks in advance
      richard
        robert-hh @davorin
        @davorin Did you set in config.py:
        SERVER = 'router.eu.thethings.network'
        PORT = 1700
        Abd did you register the gateway in TTN?
          davorin
          Of course I did this...
          Oddly it was able to connect shortly...connected vi a a SUB3 hub as I thought it might be a power issue...
          TTN console shows: Last Seen 13 minutes ago
          But now the board core dumped again and can't reconnect....
          Giving up with this broken board..definitively dumping it to trash now...
            It took me a while as well, but now it seems to be working for me. Not sure why it takes this long (I've been at it at the same time as you). Could be related to TTN?
            I have not yet had the coredumps this time. But I'll look into it
              davorin @Gijs
              @Gijs Dunno if TTN updates the registration immediately or at a specific interval...
              at least now it says "Last seen 30 minutes ago"..so meaning it can't reconnect.....
              But had the core dumps from beginning, regardless which version and if using FATFS or LFS....
              Interestingly the LoPy4 answers pings now in second intervals..before it was only every 3 - 5 seconds....
                What I mean there, is that for TTN, it sometimes seems to take ages (for me) before 'connected' appears and it starts to receive status update packets on the platform. In other times, it connects almost instantly. Earlier this afternoon I had been waiting around 30 minutes and never saw connected, but without changing anything to the script, it suddenly appeared and stayed connected.
                Again, I'll check on the coredumps, assuming you're using this version? https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway
                What do you mean with this? In general, pings should take less than 10ms on a local network..
                  davorin @Gijs
                  @Gijs Dunno which pybytes version it was....but had it that the LoPy4 board only replied to every 3rd or 4th ping...looked like it was busy doing something else (o;
                  Yes..using extact this nanogateway.py version...
                  Thanks for looking into the core dump issue....
                  cheers
                  richard
                    Well, if you're running the nano gateway alongside pinging it, that could introduce some additional delays, as the nanogateway is quite socket-intensive, though I would not expect 3-5 seconds of delay there..
                    Just to confirm, did you erase the device fully (clear NVS and CONFIG partitions as well as erase the flash) before starting?
