Atom repl window gone
Foolishly downloaded the latest pymakr & now Atom has no repl window. My usual trick of unistalling pymakr from within Atom then unistalling Atom, downloading & installing the latest atom, reinstalling pymakr isn't working.
The .atom files described in https://atom.io/packages/pymakr don't seem to exist anywhere on my windows machine so I can't install pymakr manually. Any one got any clues for getting pymakr 2.1.9 working in Atom 1.54.0? Or indeed how to get any version of pymakr working in any version of Atom?
@Clyde-Bess I can confirm that downgrading to 1.50.0 on windows worked for me.
I am having the same issue with Atom 1.56.0 and pymakr 2.1.9
just install a older release of Atom 1.50.0 - can confirm after downgrade on mac it works like before
pymakr has done another of it's periodic disappearing acts from Atom. Usually I just uninstall everything & start again with a clean slate. Doesn't seem to be working this time. Thoughts anyone?
Installing “pymakr@2.1.9” failed.Hide output…
@serialport/bindings@8.0.8 install C:\Users\Admin\AppData\Local\Temp\apm-install-dir-2021315-5180-hb5hgi.23ml\node_modules\pymakr\node_modules@serialport\bindings
prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuildC:\Users\Admin\AppData\Local\Temp\apm-install-dir-2021315-5180-hb5hgi.23ml\node_modules\pymakr\node_modules@serialport\bindings>if not defined npm_config_node_gyp (node "C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\....\node_modules\node-gyp\bin\node-gyp.js" rebuild ) else (node "C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
npm WARN deprecated parser-cctalk@1.0.2: reanmed to @serialport/parser-cctalk
npm WARN deprecated parser-byte-length@1.0.2: renamed to @serialport/parser-byte-length
npm WARN deprecated parser-delimiter@1.0.2: reanmed to @serialport/parser-delimiter
npm WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline
npm WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-ready
npm WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
prebuild-install WARN install No prebuilt binaries found (target=9.4.4 runtime=electron arch=x64 libc= platform=win32)
gyp ERR! find Python
gyp ERR! find Python Python is not set from command line or npm configuration
gyp ERR! find Python Python is not set from environment variable PYTHON
gyp ERR! find Python checking if "python" can be used
gyp ERR! find Python - executable path is "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.9_3.9.1264.0_x64__qbz5n2kfra8p0\python3.9.exe"
gyp ERR! find Python - "C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.9_3.9.1264.0_x64__qbz5n2kfra8p0\python3.9.exe" could not be run
gyp ERR! find Python checking if "python2" can be used
gyp ERR! find Python - "python2" is not in PATH or produced an error
gyp ERR! find Python checking if "python3" can be used
gyp ERR! find Python checking if the py launcher can be used to find Python 2
gyp ERR! find Python - "py.exe" is not in PATH or produced an error
gyp ERR! find Python checking if Python is C:\Python27\python.exe
gyp ERR! find Python - "C:\Python27\python.exe" could not be run
gyp ERR! find Python checking if Python is C:\Python37\python.exe
gyp ERR! find Python - "C:\Python37\python.exe" could not be run
gyp ERR! find Python **********************************************************
gyp ERR! find Python You need to install the latest version of Python.
gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
gyp ERR! find Python you can try one of the following options:
gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
gyp ERR! find Python (accepted by both node-gyp and npm)
gyp ERR! find Python - Set the environment variable PYTHON
gyp ERR! find Python - Set the npm configuration variable python:
gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
gyp ERR! find Python For more information consult the documentation at:
gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Python installation to use
gyp ERR! stack at PythonFinder.fail (C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)
gyp ERR! stack at PythonFinder.runChecks (C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)
gyp ERR! stack at PythonFinder.<anonymous> (C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)
gyp ERR! stack at PythonFinder.execFileCallback (C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
gyp ERR! stack at exithandler (child_process.js:297:5)
gyp ERR! stack at ChildProcess.errorhandler (child_process.js:309:5)
gyp ERR! stack at ChildProcess.emit (events.js:200:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:270:12)
gyp ERR! stack at onErrorNT (internal/child_process.js:456:16)
gyp ERR! stack at processTicksAndRejections (internal/process/task_queues.js:84:9)
gyp ERR! System Windows_NT 10.0.19042
gyp ERR! command "C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\bin\node.exe" "C:\Users\Admin\AppData\Local\atom\app-1.56.0\resources\app\apm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\Admin\AppData\Local\Temp\apm-install-dir-2021315-5180-hb5hgi.23ml\node_modules\pymakr\node_modules@serialport\bindings
gyp ERR! node -v v12.4.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm WARN notsup Unsupported engine for pymakr@2.1.9: wanted: {"atom":">=1.41.0","node":">=6.3.0 <=7.0.0"} (current: {"node":"12.4.0","npm":"6.14.8"})
npm WARN notsup Not compatible with your version of node/npm: pymakr@2.1.9
npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Admin\AppData\Local\Temp\apm-install-dir-2021315-5180-hb5hgi.23ml\package.json'
npm WARN apm-install-dir-2021315-5180-hb5hgi.23ml No description
npm WARN apm-install-dir-2021315-5180-hb5hgi.23ml No repository field.
npm WARN apm-install-dir-2021315-5180-hb5hgi.23ml No README data
npm WARN apm-install-dir-2021315-5180-hb5hgi.23ml No license field.npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@8.0.8 install:prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@8.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\Admin.atom.apm_logs\2021-04-15T05_34_42_567Z-debug.log
@Matthew-Felgate-0 Atom 1.54.0 seems stuck on whatever version of pymakr is in place. If I click uninstall pymakr, close Atom then open it again it shows pymakr still there. If I check for package updates it says it has the latest version. Do you know if the info at https://atom.io/packages/pymakr is current? I can't find any trace of .atom files on this windows10 machine.
Hi @kjm
I have Atom 1.54.0 and pymakr 2.1.9 working on Mac with REPL interface.
What problems are you having re-installing pymakr?
Matt
