    Lopy and Node-Red communication
    5 Posts 2 Posters 71 Views 2 Watching
    • N Offline
      newkit
      I’ve got a Lopy with Pytrack extension board and have been playing around with GPS coordinates.
      Now I’d like to connect to Node-Red, which I installed on my PC (Windows 10). What is the easiest way to send data between Lopy and Node-Red for testing purposes?
      I’ve tried this via the serial port but did not succeed. I’ve to admit I’m bit of a beginner at this and hoping that someone can point me in the right direction.
      I installed the serial nodes in Node-Red and set this to COM3 (9600 baud rate). This shows the Lopy as connected.
      Then I created a simple loop to print every 5 seconds from the Lopy. I can see this in the REPL console but not in the debug window in Node-Red. I figured instead of print, I should use uart.write and added the following bits to my code:
      from machine import UART
      uart = UART(0, 9600)
          time.sleep(5)
          uart.write("Test")
      However still no output in Node-Red. Also tried 115200 baud rate and UART1.
      Where am I going wrong? Or is there perhaps a better way to communicate between Lopy and Node-Red, other than the serial port?
      Also a little sub-question: how can I send l76.coordinates of the Lopy to Node-Red? I know uart.write expects bytes object or string, not tuple. Is there an easy way to convert or an alternative to uart.write that works with tuple?
      Many thanks in advance!
      • M Offline
        Matthew Felgate 0 Global Moderator
        Hi
        Maybe using MQTT on Lopy to send messages into Node-Red (via a MQTT broker) may be a way to do it?
        • N Offline
          newkit @Matthew Felgate 0
          Thanks @Matthew-Felgate-0, that's a good suggestion. Will give MQTT a try.
          Still curious though where I went wrong on the serial port. If someone sees an obvious error, please let me know.
          • M Offline
            Hi @newkit
            I have got node-red Serial node working. In Node Red I have /dev/tty.usbmodemPy91b3c81. Your board will have a similar name. note: make sure there is no empty space at the end of the name and baud rate set to 115200.
            Node Red debug output:
            04/03/2021, 15:08:12node: 7cae131c.d729ec
            msg.payload : string[6]
            "hello↵"
            msg.payload : string[13]
            "print hello↵"
            msg.payload : string[2]
            I think your serial connection in terminal or Visual Studio will need to be closed else you won't get the data into Node-Red. (I think serial data can only be read at one place at a time)
            Here is my code for reference:
            boot.py
            import os
            uart = UART(0, 115200)
            os.dupterm(uart)
            main.py
            print('Hello World!')
                uart.write('hello\n')
                print('print hello\n')
                time.sleep(5)
            print('The End.')
            Let me know if that works for you?
            N 1 Reply Last reply Reply Quote 1
            • N Offline
              Brilliant @Matthew-Felgate-0 the example is working for me and I was able to integrate this into my project. Thanks!
              But now you also got me interested in MQTT :)
              I followed some of the examples from here and here.
              However I always run into the same error leading back to the mqtt library:
                File "main.py", line 19, in <module>
                File "/flash/lib/mqtt.py", line 65, in connect
              OSError: Network card not available
              This is line 65 in the connect function:
              self.sock = socket.socket()
              I tried various MQTT brokers, e.g. HiveMQ ,test.mosquitto.org, as well running mosquito locally.
              But I just can’t get past the above error.
              Any idea?
