LTE issues on FW 1.20.2.rc10 with double precision
Re: Pycom firmwares with single/double precision and ulab module
Hi @rcolistete , I must use your FW from GitLab to have float numbers in dp. But this FW has an issue on LTE. It won't connect to Network-Provider and always outputs:
+--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |REGISTERED | | EMM AUTH FSM |KASME_DEFINED | | EMM CONN FSM |EMM_IDLE | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_ACTIVE | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+
If I use standard FW 1.20.2.r4, LTE attaches and connects reliable. Is there a plan to update dp FW with working LTE?
@quentinmsl said in LTE issues on FW 1.20.2.rc10 with double precision:
@Christian-Storm see : https://forum.pycom.io/topic/7328/pycom-firmwares-double-precision-float
Hey @quentinmsl , I think I found an UART reading bug on FW 2.5. I opened an issue on GitHub. BR
Hi @rcolistete any updates on updating firmware to support LTE with double precision?
I hope to have time next weekend to update Pycom MicroPython firmwares with sp/dp, ulab, etc.
