    LTE modem firmware release for Cat-M1 5.2-48829
    9 Posts 5 Posters 432 Views 5 Watching
      peterp
      Dear Pycom community!
      We're happy to announce the release of a new firmware for the LTE modem for CAT-M1. It can be used for existing FiPy, GPy and G01 modules.
      This new firmware release is much more stable than previous CAT-M1 releases.
      Forum users can find the download link in this post and please note the two step upgrade process explained in the upgrade instructions in the docs.
      Regards,
      Peter
      1 Reply Last reply Reply Quote 4
      • K Offline
        kjm
        We'd like to try this on a 1.20.3.b0 fiPY but when we try
        >>> import sqnsupgrade; sqnsupgrade.info()
        ImportError: no module named 'sqnsupgrade'
        there is not an obvious way to do it. Is there another way to upgrade modem firmware? If not is there a firmware version for the fiPY that has sqnsupgrade in it?
        Also the modem firmware update guide mentions "Our newest products ship with the modem firmware version CAT-M1 5.4.1.0-50523. At the moment it is not possible to update the modem to that version." Do you have a timeline for when this might be possible since our suppliers are still shipping FiPYs with 43818 modem firmware.
          peterp @kjm
          @kjm Yes that beta firmware does not include the sqnsupgrade. You can take it from here https://github.com/pycom/pycom-libraries/tree/master/lib/sqnsupgrade Or you used (temporarily) another firmware such as 1.20.2.r4 to perform the upgrade
          • K Offline
            kjm @peterp
            @peterp In https://docs.pycom.io/updatefirmware/ltemodem/ I'm wondering if
            sqnsupgrade.run('/sd/CATM1-5.2-48829-2.dup', load_fff=False)
            should be
            sqnsupgrade.run('/sd/CATM1-5.2-48829-1.dup', load_fff=False)
            otherwise 1.dup is not used anywhere in the 2 step process?
            P 1 Reply Last reply Reply Quote 1
              peterp @kjm
              @kjm Yes, you're right. Thanks for flagging! We'll update it.
                Paul Harvey
                Is there a comparable update for the NB-IoT firmware?
                We are finding our current FiPy/1.20.0.rc13/LR6/41019 firmware impossible to connect on NB-IoT in the US. Anyone know of a working combination?
                  Could you first try to use the latest firmware (1.20.2.r4) and let us know. Also I recommend to create a separate thread for your issue instead of adding onto a CAT-M1 modem firmware thread :), just to keep things separate
                    Alexander Pilhar
                      Paul Harvey @Gijs
                      @Gijs Yes, no luck for us using 1.20.2.r4 neither. Still haven't been able to connect in US. Will create another post as you suggest and continue to solve it there.
