    Error starting modem connection
    4 Posts 3 Posters 174 Views 3 Watching
    • M Offline
      Massimo Rebellato
      I am trying to connect to vodafone network using the example found in "Tutorials & Examples > Networks > LTE"
      I have connected the gpy module to the pc as shown in "Getting Started > Getting Started Programming the modules > USB Serial"
      When I try to run the example code, I get the following error: "OSError: Couldn't start connection to Modem (modem_state=disconnected)"
      After many retries, sometimes, the example starts without errors but goes in an infinite loop:
      +SYSSTART
      SYSTEM FSM
      |            FSM           |        STATE       |
      | RRC TOP FSM              |STOPPED             |
      | RRC SEARCH FSM           |NULL                |
      | RRC ACTIVE FSM           |NULL                |
      | PMM PLMN FSM             |NULL                |
      | EMM MAIN FSM             |NULL                |
      | EMM AUTH FSM             |NULL                |
      | EMM CONN FSM             |NULL                |
      | EMM TAU FSM              |NULL                |
      | EMM TEST FSM             |NULL                |
      | ESM BEARER FSM           |BEARER_NULL         |
      | SMS MT FSM               |IDLE                |
      | SMS MO FSM               |IDLE                |
      | HP MAIN FSM              |IDLE                |
      | HP USIM FSM              |NULL                |
      | HP SMS MO FSM            |IDLE                |
      | HP SMS MT FSM            |IDLE                |
      | HP CAT FSM               |NULL                |
      OK
      +SYSSTART
      SYSTEM FSM
      |            FSM           |        STATE       |
      Thanks for any help.
        Could you let me know of the output with lte =LTE(debug=True), that way, we can verify the AT commands. Also be sure to verify the power supply capabilities, as the LTE modem might consume more current than expected
        Could you also let me know of the following output:
        import sqnsupgrade
        sqnsupgrade.info(debug=True)
        This will return a coredump at the end, please do not copy that over, but only the text at the top.
        Let me know,
          Jeroen Trappers
          @Gijs said in Error starting modem connection:
          I have the same issue.
          Connecting to /dev/ttyACM0...
          WMAC: 840D8E116C98
          Firmware: 1.20.2.r4
          Pybytes: 1.6.1
          Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
          WiFi connection established
          Connected to MQTT mqtt.pybytes.pycom.io
          Pybytes connected successfully (using the built-in pybytes library)
          Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; GPy with ESP32
          Pybytes Version: 1.6.1
          >>> from network import LTE
          >>> lte = LTE()
          >>> import sqnsupgrade
          <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
          >>> GPy with firmware version 1.20.2.r4
          The current delay is 1000
          Response (+++ #1): None
          Response (AT #1) None
          Response (AT #3) None
          Response (AT #4) None
          Response (AT #1 @ 115200) None
          Response (AT #2 @ 115200) None
          The current delay is 2000
          The current delay is 3000
          The current delay is 4000
          The current delay is 5000
          Modem state: None
          Cannot determine modem state!
            @Jeroen-Trappers Sorry for my late reply.
            Could you try to power cycle the modem and see if that results in any progress?
            If not, can you update the modem over UART using the instructions here: https://docs.pycom.io/updatefirmware/ltemodem/
            Let me know!
