    WiPy re-use UART-REPL ports P0/P1 for other purpose
    3 Posts 2 Posters 50 Views 2 Watching
    • K Offline
      Kaspars Golts
      I am using WiPy on Pygate. Unfortunately there is no real way to attach any external device to this expansion boar, as exposed pin headers are limited to UART for programming and REPL. I am wondering is there a way to disable UART on P0 and P1 to use these for other purposes? I don't mind not having terminal over USB as long as I can still see output via telnet.
      From Pygate_v1.pdf
        livius
        Starting point will be uos.dupterm(None)
        • K Offline
          Kaspars Golts
          Thanks, that really did the trick. I added it in the boot.py together with 3 sec sleep period in order to interrupt it if I need to load new code.
          time.sleep(3)
          uos.dupterm(None)
          This way both P0 and P1 pins were released and can be re-used
