Pygate & Wifi connection issues
Hey, got a strange issue. Pygate+LoPy4 usually connects to WiFi effortlessly, when the WiFi is in an already switched on state.
But when I switch on both my Pygate & WiFi router simultaneously, the pygate does not connect, once the WiFi connection is stable. It continuously lies in the below loop.
while not wlan.isconnected(): print('.', end='') time.sleep(1)
I forsee an issue of having a power outage, and then when the power is back, the pygate wont connect.
Kindly help.
You're correct there's no failsafe implemented in the pygate example. You could for example issue a
machine.reset()
if connecting takes too long, or if the connection is dropped (though you'll have to write your own checking method to verify the connection is still up)
1 out of 2
