    Pybytes battery level doesn’t show up
    5 Posts 3 Posters 83 Views 3 Watching
      Clyde Bess
      If I use:
      pybytes.send_battery_level(battery_level)
      .. there is no data visible under pybytes notification.
      If I send it via it works without any problems..
      Doesn’t matter what I try... even if I just send an int.
      The status of the device battery doesn’t show up..
      And sometimes even the setup under the notification tab disappear and i have to set it up again..
      Can someone please advice me what I am doing wrong?
      Kind regards,
      Clyde
        Battery level reporting is unfortunately not properly setup on the Pybytes end, and I can reproduce the experience.
        I could not find a feature / bug report yet, so I added it to the list! Thanks for notifying us.
        Edit: I just revisited Pybytes, and the notification I set for low battery showed:
          Clyde Bess @Gijs
          @Gijs Thnaks for your respond - i didnt got notified that you edited your answer.
          How does Pybytes calculate the critical state? i got all kind of notifications.. but they are not really helpful...
          kind regards,
          Clyde
            I was not even aware there was a distinction. It has to be around 10-15% that the notification text switches.
              Lorie Petty
