    BLE notifications with FIPY as client
    blenotifycharacteristiccallback
    2 Posts 2 Posters 64 Views 2 Watching
    • F Offline
      Fredrik Andersson
      Hi, can't get callback(trigger=Bluetooth.CHAR_NOTIFY_EVENT, handler=char_notify_callback,arg=None) to work. Read some threads and some say it is not possible to use notification (due to missing descriptor functions..) other report that it does work.
      Can anyone clarify this?
      • M Offline
        Meriç SARIIŞIK
        Hi Fredrik,
        First of all, CHAR_NOTIFY_EVENT works well on FiPy.
        Could you tell me which version you are using? I tried my example on different versions and I haven't seen a missing descriptor error.
        You can try the examples below. Please let me know about your experiment.
        BR,
        Meric
        Subscribe_Event
        def chr1_handler(chr, data):
            global battery
            global update
            events = chr.events()
            print("events: ",events)
            if events & (Bluetooth.CHAR_READ_EVENT | Bluetooth.CHAR_SUBSCRIBE_EVENT):
                chr.value(battery)
                print("transmitted :", battery)
                if (events & Bluetooth.CHAR_SUBSCRIBE_EVENT):
                    update = ~update
        bluetooth = Bluetooth()
        bluetooth.set_advertisement(name='FiPy 45', manufacturer_data="Pycom", service_uuid=0xec00)
        bluetooth.advertise(True)
        srv1 = bluetooth.service(uuid=0xec00, isprimary=True,nbr_chars=1)
        chr1 = srv1.characteristic(uuid=0xec0e, value='read_from_here') #client reads from here
        chr1.callback(trigger=(Bluetooth.CHAR_READ_EVENT | Bluetooth.CHAR_SUBSCRIBE_EVENT), handler=chr1_handler)
        def update_handler(update_alarm):
            global battery
            global update
            battery-=1
            if battery == 1:
                battery = 100
            if update:
                chr1.value(battery)
        update_alarm = Timer.Alarm(update_handler, 1, periodic=True)
        Notify_Event
        def char_notify_callback(char, arg):
            char_value = (char.value())
            print("New value: {}".format(char_value))
        bt = Bluetooth()
        bt.start_scan(-1)
        adv = None
        while(True):
            adv = bt.get_adv()
            if adv:
                try:
                    if bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL)=="FiPy 45":
                        conn = bt.connect(adv.mac)
                        try:
                            services = conn.services()
                            for service in services:
                                time.sleep(0.50)
                                chars = service.characteristics()
                                for char in chars:
                                    c_uuid = char.uuid()
                                    if c_uuid == 0xec0e:
                                        if (char.properties() & Bluetooth.PROP_NOTIFY):
                                            char.callback(trigger=Bluetooth.CHAR_NOTIFY_EVENT, handler=char_notify_callback)
                                            print(c_uuid)
                                            break
                        except:
                            continue
                except:
                    continue
        bt.stop_scan()
        bt.disconnect_client()
