    [SOLVED] WiPy 2.0 on Pybytes?
    5 Posts 2 Posters 85 Views 2 Watching
    • B Offline
      BetterAuto Pybytes Beta
      Will WiPy 2.0 work with provisioning, installing code, firmware updates, all that? I don't yet have a 3.0.
      And I can't access my 2.0 for a few days, hence I am asking instead of trying it. As soon as I get an answer I'll either buy a 3.0 immediately or just wait til I get my 2.0 in hand.
      • B Offline
        Main concern is the constrained RAM and flash space for the partitions. Since the LoPy and SiPy are supported, and they have 512KB/4MB, I feel comfortable that my WiPy 2.0 with 512KB/4MB will work.
        If anyone tells me differently in the next few days though I will place the order.
          I believe the Wipy 2.0 should still be compatible with Pybytes. Im not sure if it will run the latest stable firmware (1.20.2.r4) reliably and allow for a lot of micropython code, because the firmware size increased somewhat since the Wipy 2 was released, but you should be able to make it work with an earlier release if the latest does not work in your application
          • B Offline
            BetterAuto Pybytes Beta @Gijs
            @Gijs said in WiPy 2.0 on Pybytes?:
            Well it boots up on 1.20.2.r4, but as soon as I try to initialize the WiFi I get a guru meditation. Will try an older version.
            configsip: 0, SPIWP:0xee
            mode:DIO, clock div:1
            load:0x3fff8020,len:8
            load:0x3fff8028,len:2128
            load:0x4009fa00,len:19760
            entry 0x400a05bc
            WMAC: 240AC400B1B6
            Firmware: 1.20.2.r4
            Pybytes: 1.6.1
            Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
            WiFi connection established
            Connected to MQTT mqtt.pybytes.pycom.io
            Pybytes connected successfully (using the built-in pybytes library)
            Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; WiPy with ESP32
            Pybytes Version: 1.6.1
            >>> print('Hello world')
            Hello world
            • B Offline
              Problem was I wasn't using 5V on VCC and the guru meditation was coming from not having enough power.
