    Bluetooth.CHAR_NOTIFY_EVENT When triggered
    8 Posts 3 Posters 83 Views 3 Watching
      Little Freak
      Hey, I am trying this Tutorial https://docs.pycom.io/tutorials/networks/ble/callback/ and it doesn't execute the char_notify_callback function in the client.
      So my question is, when does the Bluetooth.CHAR_NOTIFY_EVENT get triggered?
      Where can I find the source code of the network lib?
      I use 2 LoPys, one of them is the client and the other one the server
        Could you perhaps add some print statements to see where the code stops?
        When trying this example, I did have some difficulty syncing both devices up (with correct connection / disconnection status) But was able to make it work
          Little Freak @Gijs
          @Gijs in the client I never get in the char_notify_callback method and also never send a read request.
          If I try a char.read() after the line, where I call the Callback method, then I get this error:
          Unhandled exception in callback handler
          TypeError: function takes 2 positional arguments but 1 were given
            Are you running the same firmware on both devices, I tried with the latest stable release, 1.20.2.r4. Also, could you check whether the conn_cb is triggered on the Server device, and whether Connected to FiPy 45 is printed on the Client?
            Im not sure what you mean with char.read()?
              Little Freak @Gijs
              @Gijs An update fixed my problem, thank you.
              Do you know, when this in the server is triggered?
              chr1.callback(trigger=(Bluetooth.CHAR_READ_EVENT | Bluetooth.CHAR_SUBSCRIBE_EVENT), handler=chr1_handler)
                When you read the characteristic. The actual reading is done at conn.services(), but we later register the callback on the Client side. a CHAR_READ_EVENT triggers the callback on the server side to send data
                  Little Freak @Gijs
                  @Gijs where can i find a documentation, where the trigger is discribed?
                    livius @Little Freak
                    @Little-Freak
                    https://docs.pycom.io/firmwareapi/pycom/network/bluetooth/gattscharacteristic/#characteristiccallbacktriggernone-handlernone-argnone
